Hello, I have successfully installed PinballX,
some Future Pinball tables are already running.
When I leave the tables, PinballX is also ended. I don't find the mistake.
I used the google translator !! thank you for your help
You'll need to attach copies of your config and log files after exiting a table.
Log file - .Pinballx\Log\Log.txt
Config file - Pinballx\config\pinballx.ini
Hi , log.txt is here:
20:33:11.17  02.03.2020:  PinballX - Version 4.13 x64
20:33:11.29  02.03.2020:  Windows 10 Pro 64-Bit (7GB)
20:33:11.30  02.03.2020:  Loading Settings
20:33:11.32  02.03.2020:  Initialize Component
20:33:11.36  02.03.2020:  Initialize Display
20:33:11.48  02.03.2020:  Testing Flash engine.
20:33:12.77  02.03.2020:  Loading PlugIns
20:33:13.13  02.03.2020:  Created DirectX BackGlass Window
20:33:13.14  02.03.2020:  Looking for startup images
20:33:13.52  02.03.2020:  Hiding Cursor
20:33:13.58  02.03.2020:  Hiding Taskbar
20:33:13.60  02.03.2020:  Getting GPU and CPU Information
20:33:13.66  02.03.2020:  CPU:  AMD FX-8800P Radeon R7, 12 Compute Cores 4C+8G
20:33:13.67  02.03.2020:  4 cores, 4 threads
20:33:13.68  02.03.2020:  GPU 1: AMD Radeon R7 Graphics
20:33:13.69  02.03.2020:  Displays: 2
20:33:13.70  02.03.2020:  Load Game List
20:33:13.82  02.03.2020:  Loading Database: Future Pinball
20:33:13.88  02.03.2020:  Initial load gamelist took: 62ms
20:33:13.99  02.03.2020:  Finding and matching artwork and videos
20:33:14.17  02.03.2020:  Took: 172ms
20:33:14.18  02.03.2020:  Loading Game Statistics and Scores
20:33:14.23  02.03.2020:  Main display running full screen windowed.
20:33:14.32  02.03.2020:  Loading Surfaces
20:33:14.43  02.03.2020:  Finished Loading Surfaces
20:33:14.44  02.03.2020:  Initialize Audio
20:33:14.51  02.03.2020:  Set Keyboard Controls
20:33:14.53  02.03.2020:  Initialize Joystick
20:33:14.73  02.03.2020:  1 Joystick Attached
20:33:14.74  02.03.2020:  Started
20:33:27.74  02.03.2020:  Launch System
20:33:27.76  02.03.2020:  Hide Backglass
20:33:27.77  02.03.2020:  Waiting for threads
20:33:27.78  02.03.2020:  Disposing display
20:33:28.24  02.03.2020:  C:\Future Pinball\Future Pinball.exe /open "C:\Program Files (x86)\Future Pinball\Tables\Apollo 13 1.1.fpt" /play /exit /arcaderender
20:33:38.49  02.03.2020:  Zugriff verweigert
20:33:38.50  02.03.2020:     bei System.Diagnostics.ProcessManager.OpenProcess(Int32 processId, Int32 access, Boolean throwIfExited)
20:33:38.51  02.03.2020:     bei System.Diagnostics.Process.GetProcessHandle(Int32 access, Boolean throwIfExited)
20:33:38.52  02.03.2020:     bei System.Diagnostics.Process.get_HasExited()
20:33:38.53  02.03.2020:     bei PinballX.FrmMain.x()
20:33:40.83  02.03.2020:  Created DirectX BackGlass Window
20:33:44.65  02.03.2020:  Main display running full screen windowed.
20:33:46.06  02.03.2020:  HRESULT: [0x88760868], Module: [Unknown], ApiCode: [Unknown/Unknown], Message: Unknown
20:33:46.26  02.03.2020:  Error. Exiting
20:33:46.28  02.03.2020:  Video_none
20:33:46.30  02.03.2020:  HRESULT: [0x88760868], Module: [Unknown], ApiCode: [Unknown/Unknown], Message: Unknown
20:33:46.32  02.03.2020:     bei PinballX.FrmMain.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
20:33:46.35  02.03.2020:     bei PinballX.FrmMain.ax()
20:33:46.36  02.03.2020:     bei PinballX.FrmMain..ctor()
20:33:46.38  02.03.2020:  Disposing Plugins
20:33:46.40  02.03.2020:  Showing Taskbar
20:33:46.47  02.03.2020:  Unhiding Mouse Cursor
20:33:46.57  02.03.2020:  Bye
Ini Datei:
[Display]
Monitor=0
rotate=0
Windowed=False
windowwidth=812
windowheight=457
windowx=543
windowy=752
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
[BackGlass]
monitor=0
x=0
y=0
width=1920
height=1080
AutoPositionB2S=True
[DMD]
Enabled=False
monitor=2
x=0
y=0
width=900
height=300
AutoPositionPinMAME=False
[FileSystem]
EnableFileMatching=True
[Interface]
UseTableLoadingMedia=True
GIFbackgroundcolor=ff000000
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[Startup]
playsound=True
playvideo=True
StartWithWindows=Yes
[KeyCodes]
quit=27
left=37
right=39
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=81
ingame=80
screenshot=83
capturevideos=86
instructions=73
volumedown=109
volumeup=107
credit=53
plunger=164
launch=50
[JoyCodes]
quit=5
left=0
right=1
select=7
rotate=
pageleft=
pageright=
exitemulator=4
ingame=
instructions=
launch=8
Credit=
Plunger=8
[Text]
All=All
PlayGameTwoPlayer=Two Player Game
Line1=Vossi läd zum FLIPPERN ein
Line2=Press Start
Featuring=Featuring
Tables=Tables
PlayGame=Play Game
Instructions=Instructions
Information=Information
Flyer=Flyer
Gameplay=Gameplay
Tutorial=Tutorial
Promo=Promo
ExitGame=Exit Game
ReturnToGame=Return to Game
Return=Return
Exit=Exit
Shutdown=Shutdown
Favorite=Favorite
Favorites=Vossis Favoriten
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
MostPlayed=Most Played
LastPlayed=Last Played
Lists=Lists
CapturingVideos=Capturing videos. Please wait. This will take several minutes.
Ratings=Ratings
HighScores=High Scores
RateTable=Rate Table
NotRated=Not Rated
Systems=Systems
RecentlyAdded=Recently Added
[FuturePinball]
WorkingPath=C:\Future Pinball
TablePath=C:\Program Files (x86)\Future Pinball\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterExecutable=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
FPRAMPath=C:\Future Pinball\fpRAM
[VisualPinball]
Enabled=False
WorkingPath=h:\-PINBALL-\- VISUAL PINBALL -
TablePath=h:\-PINBALL-\- VISUAL PINBALL -\Tables
Executable=VPinball_9_0_2.exe
AutoConfigure=False
[ExitScreen]
EnableExit=True
EnableShutdown=True
[StartupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=False
WorkingPath=C:\PinballX
Executable=PinballX.exe
Paramaters=
HideWindow=False
WaitForExit=True
Parameters=/open
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[System_1]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
Enabled=False
[PinballFX2]
Enabled=False
Executable=steam.exe
Parameters=-applaunch 226980 [TABLEFILE]
Process=Pinball FX2.exe
Rotate=False
WaitFor=20
[PinballArcade]
Parameters=-applaunch 238260
Process=PinballArcade.exe
WaitForSelect=50
[GameListManager]
onlinemode=false
[RealDMD]
EnableColor=True
Color=ffff1414
[PinballFX3]
Parameters=-applaunch 442120 "-table_[TABLEFILE]"
Process=Pinball FX3.exe
Rotate=False
WaitFor=20
[Topper]
monitor=2
[VideoCapture]
KeysStartRecord=164|120
KeysEndRecord=164|120
Seconds=30
UseGPU=False
SavePath=C:\PinballX\Videos
[Internal]
lastwheelcachematchsize=-1123
lastselected=addamsCABaddamsCABSystem_2
filter_year=
filter_company=
filter_custom=
filter_favorites=False
filter_lastplayed=False
filter_mostplayed=False
filtername=Tables
filter_rating=0
filter_system=
filter_recentlyadded=False
[Plugin_1]
Enabled=False
Name=PlugInLED.dll
[Plugin_2]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_3]
Enabled=False
[Plugin_4]
Enabled=False
Name=Xpadder Plugin.dll
[Apron]
monitor=3
[General]
Language=German
[SetupWizard]
EmuPath1=C:\Emulation\Emulators
AssetPath1=C:\Emulation\Assets
ROMPath1=C:\Emulation\ROMs
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=Custom
SavePosition=False
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=1
ShowPanel=True
FontSize=1
WindowSize=650, 814
WindowLocation=156, 426
WindowState=Normal
CustomArray=Auto Exit~Exit Screen~Exit Program
SearchArray=
SectionIndex=20
[frmInfo]
Size=386, 322
Location=288, 672
WindowState=0
[System_2]
Name=
Enabled=False
SystemType=2
WorkingPath=
TablePath=
Executable=
Parameters=
LaunchBeforeEnabled=False
Next time just attache the files instead of past :p
isee a "Zugriff verweigert"(access denied)
can you try to run pinballx as admin and redo the test ?
Embarrassing, it runs as an administrator. Thank you very much.
Let's see, I want this to start automatically when the PinballX computer starts. I'm going to test it out. Many thanks for the help
No problem my friend
We all be in the same startup issues. Thats why we try to help each other.
Best way is to right click the executable and select properties.  There is an option to set "run as admin:"  this will always run the program as admin
