XP, 3gHz P4, 2 GB RAM.
Visual Pinball 8 - I have this emulator running fine in the VPMan FE,  but I can't launch tables through GameEx--  after the "donk" and a black screen for a few seconds,  GameEx minimizes, and I see the error box: "error loading file".  Tables show up fine in the menu, and as far as I can tell I have everything set up right, but note that I doubt that Visual PinMAME is set up properly.  In the setup program I see a reference to a "vp.aut script for visual pinmame", but I can't find such a thing anywhere.
Thanks in advance for any help!
Yeah, that would probably help, huh. :wacko:
Colecovision problem solved; color setting issue in VColeco that didn't bother to raise it's head 'til now.  VP8 problem persists.
Thanks for your help!
GameEx.ini log.txt
  • ARH changed the title to Visual Pinball 8
That did it!!!
(Could have sworn that that's how it was set up when I first started trying to "fix" it, but there you go.)
Thanks VERY much.
