Just now, slashguns04 said:
I have already seen this page but there are no such tables in the list
so that's the reason i can not create them for those 3 table they just don't exist no pdf no instruction swf cards
Press the instructions key in pinball x or press select key and choose instructions in menu. If instructions exist and they are named correctly the menu entry should show up. If your asking how to name them:
Page 1: [TableName].SWF or [Table Description].SWF
Page2 [TableName] 1.SWF or [Table Description] 1.SWF
Page3  [TableName] 2.SWF or [Table Description] 2.SWF
etc
2 minutes ago, slashguns04 said:
how do you go from page 01 to page 02?
You do it with flipper buttons. But you need Pinball X Frontend version 4.08 minimum (so update pinball x frontend first) in old versions it was not working
8 minutes ago, slashguns04 said:
thank you! how to configure the startup video pinball x?
don't know not sure is possible have not verified perhaps this is correct folder PinballX\Media\Startup Videos. But next time open NEW topic in GENERAL section if you are asking different things to keep topics on TOPIC
