Is there something I need to do to get Future Pinball to record properly? It seems like perhaps there needs to be a configurable recording delay available since it takes some of those tables awhile to load?
Attached is what happened when I tried to record the first one.
Here is my future pinball config.
PinballX.ini
Log please.
FFMPEG GDI capture does not work with future pinball as far as I know. Try the driver capture. Your log would tell me if you have an NVIDIA and whether you are already using driver capture.
Just installed Future Pinball and having the same issue, just recording a black video for table and backglass. I tried changing to gpu (Radeon RX570) driver capture in the settings program, closing and reopening the game manager and just got a black video for the table and n o backglass capture.  I've attached two logs that I tried each way.
Thanks for any insight.
log -with gpu.txt log - without gpu.txt
As Tom mentioned. GDI capture doesnt work for future pinball. And because you have not a NVIDIA card, yiu cannot use the driver caption option.
