Does anyone have recommended settings/configuration for using a VirtuaPin controller with Pinball FX3? I am using X360CE to map the buttons to the Xbox controller in FX3, and have gotten flippers, start, and ball launch button to work okay, but can't get the plunger to do anything. I have tried mapping the plunger to the right stick, and then select RS in the FX3 options, but it doesn't work. Will try to attach image of my X360CE settings. Any suggestions are welcome. Thanks!
Yep!  I compared my settings with what I read here last night and realized that my Stick Y axis wasn't inverted.  That did the trick.  Though something in the plunger settings must be off, as I can't launch a ball with much power using it (in FX3, okay in VPX).  Will have to see if there are some adjustments in X360CE for that, or if I have to go into the VirtuaPin settings.
So I have my start button mapped to 'A', flippers are mapped, launch button seems to be good (can't remember which VirtuaPin button it's mapped to) but it works for selecting things like initials when entering high scores.  Guessing I should map the left stick to nudge/tilt?  And then I have the credit button and the big button under the cabinet that is used to exit a game in PBX/VPX, so maybe that would be the equivalent of 'escape'?  Seems like the other buttons that I see pop up on the screen are 'X' and then anything to do with the 'wizard' or changing views.
