[RESOLVED] pinball x dmd starts to backglass and backglass to dmd.
I bought  a virtual pin running pinball x with 3 monitors. the guy was supposed to come back to adjust it, but he bailed on me. the problem is, when I start it up, the backglass and dmd and switched around. if I unplug the dmd and plug it back in the correct. I need some help.to fix this. i know nothing about setting these up. I've tried the windows display settings and played around with the pinball x settings. and nothing worked.
You need to attach your pinballx.ini and log.txt files (look in pinballx\config and pinballx\log folders)
Might be as simple as changing numbers in pinballx\settings.exe Display Settings section.
Also, make sure you have the latest version of pinballx installed.
