6 hours ago, Mike_da_Spike said:
RTFM Mike  RTFM ....
Sorry ! I'm a real IT prof. Never read the manual.
Sorry ! :cheers:
No problem, btw @Mike_da_Spike try this version PinballFX3Launcher.zip  now, replace exe, run it once and check ini file, it will have added a LAUNCHBUTTON2 entry which you can change. Default is joystick button 1 which equals B button on a XBOX 360 joypad to also be used as a the launch button. Just an alternate (extra) button for LAUNCHBUTTON
just released the new v4.0 version and sources contains all the latest changes that have been added the last few days.
https://github.com/joyrider3774/PinballX_Launcher_app/releases/tag/4.0
- Added Alternate Keyboard and Joypad launch key / button (LAUNCHKEY2 and LAUNCHBUTTON2 ini settings)
- Added window dragging and startup position support (REPOSITIONWINDOW, POSLEFT, POSTOP ini settings)
documentation about the new settings has been updated as well
Do you use steam or a "standalone" version of Pinball FX3?
If you have a "standallone" version, change the PinballFX3Launcher.ini :
PATH=C:\<PATH TO FX3 exe>\Pinball FX3.exe
and change the follwoing to 1
DONTREADSTEAMPATHREG=1
This will avoid that the steam path is reading from registry (I highly recommend to use steam and install Steam)
(also remove the -offline, this will avoid you to have check the leader boards etc.)
I get to load pinball FX3 but I get 1 Player and select table
I also have an offline position because this way since PinballX does not make me have to touch any button or keyboard, leave the table directly, but with this it ignores
my PFX3 version is standra but cabinet mode activated
Change the following line
STARTPARAMS=--table_[TABLEFILE] -offline
To
STARTPARAMS=-applaunch 442120
The "table_[TABLEFILE]" is a passthrough from pbx (and tablefile will be the tablename you selected)
To
With this last one, I worked a lot thanks for your help
When I select 2 or more players, I get a screen with a message
- You cannot access the online functions at this time, maybe due ...... -
Retry    Cancel
There is a way to skip these messages
13 minutes ago, Mike_da_Spike said:
Why are you not able to get online ? Are you able to launch within fx3 a multiplayer game ?
I don't have an internet connection in the pinball
10 minutes ago, joyrider3774 said:
Add -offline parameter at the end of start parameters maybe it helps. That message has nothing todo with multiplayer or the launcher.
where and should i put it ..
I'm trying to learn all this but the truth is complicated
It is all easy. In setting.exe put it as paramater. See the next screenshot
Not sure setting it as parameter in pinball x settings app wil work the laucher only takes 1st parameter but hae not tried. Better to do it in the pinball fx 3 launchers ini file at the end of startparams if i remember correctly. Am not at home to verify atm
@susoarkangel In pinball FX3.ini change
to
STARTPARAMS=-applaunch 442120 -offline
to
After restarting and retesting, I don't know what happened but the script for pinball takes almost 1 minute to appear on the screen
Just happened across this utility tonight....... WOW did not know it existed, you sir have opened up a whole new world to me using table launched from PinballX
Installed like a dream using instructions on GitHub
THANKS !
  • 3 months later...
I installed the player select plugin last night and it is working great!  Took dumb me a few minutes to figure out which github file I needed.  Once I had the right file is was easy cheesy.  I think this will make me more likely to suggest FX3 tables when friends come over.  I never liked breaking out the keyboard to manipulate the FX3 menu.  It effectively "broke the illusion"!
Version 4.1 Released, nothing major but i added in support for changing the text colors using the ini. Github page is updated with info about the colors that needs to be in hexadecimal RGB format (color1 selected button, color2, disabled button, color3 title credits and countdown timer). If you don't need to respecify colors you don't need to download this release if it's already working for you.
  • Thanks 1
