PLEASE HELP ME WITH DEMUL in GAMEEX :
I have downloaded version 0.711 (last) ,  if I start the DEMUL emulator it's all working perfectly and all the roms work ... (NAOMI ATOMiSWAVE DREAMCAST ECC...)
I have all the extensions (bios. Roms, chd) in .ZIP format I have configured via gameex wizard the right  directories ,  the games are listed in the menu but when I enter the specific game there is no Voice "START THIS GAME," I post an example jpg ...  so i can't RUN the ROMS   my gamexe.ini attached too
GameEx.ini
I've split this into a new thread for troubleshooting Demul. This will help keep the troubleshooting subject separate and easier to reference.
Also, always provide attached copies of both your gameex.ini and log.txt files. Thanks.
Log.txt file attached? No idea as I do not run this emulator, but we need the log file when an issue is reported nonetheless. Thanks.
  • 4 months later...
2 hours ago, Galvanize said:
Hi Marcocaps,
I'm having the same issue, did you ever fixed the issue?   Any tips, thanks!
Attach copies of your gameex.ini and log.txt files.
