I switched to windows 10 and have some problems now. Doflinx and Pinballx. Doflinx windows error and Pinballxb2s size. In game the size is prefect. Here are some photos.
Thanks Rich
about the screens. Can you check in pinballx settings if your screen resolutions are still setup correctly ? Like verify the resolutions of you screens in windows to what you had defined in pinballx settings. My guess that could be the problem and if you reset it up in pinballx settings it might fix it.
Doflinx is not really pinballx / frontend related and the error screenshot does not show everything. But it seems it fails to load some file at the time it is reading ini (config file) settings. Maybe your ini contains an error or it can't find some file it tries to load
Attaching copies of your pinballx.ini and log.txt files is also in order.
