i need help with this emulator "emulator_multicpu.exe" with Arcade tv/monitor (640x480) i got an error about resolution .... standard resolution is 800x600 but my monitor is 640x480 .... so i have tried to open emulator manually and set 640x480 but when i open it with Gameex got errore and resolution switch automatically to 800x600 .....
how i can fix this ??? basically i want set 640x480
Are you needing assustance with Evolution or legacy GameEx?
You posted in the GameEx Evolution>Emulator Support subforum, so I moved your thread here.
Please attach (Do NOT copy and paste) copies of your gameex.ini and log.txt files so we can review. Thanks!
Can you attach a copy of your log.txt file from when the error occurs? Not seeing it in the log.txt file you provided previously.
Not seeing an error message. Can you screen capture the message you say you see and attach it here?
the error is about "emulator_multicpu.exe stop to working"  and if i open this emulator manually without fronted the resolution is now switched automatically to 800x600 then i have to set to 640x480 and at this point i can open the rom and play the game "WITHOUT FRONTED GAMEEX"  manually !!! then if i'll try to reopen gameex and play this game with fronted menù gameex same issue "emulatore_multicpu.exe stop to working " and resolution is to 800x600!!!  THE PROBLEM IS ABOUT RESOLUTION !!! i have to set 640x480 with gameex
Can you provide a translation of the full error message? It is difficult to read at best. Also, please provide a list of the games you are attempting to run in 640x480 mode. Thanks.
