Can you use "Other applications control color settings" for the backglass, but then adjust the monitors colour settings (i.e on the monitor itself rather than via nvidia software)?
I could, but would have to partially take apart the backbox and move the machine to get at the monitor adjustments.....and you know how that would go.....fix one thing and break another :P
  • Haha 1
Yeah, my backbox isn't the easiest access either!..
I've had an issue before where nvidia color settings weren't applied after reboot and colors got reset -  fixed for me by disabling the calibration loader task in task scheduler. Your issue appears to be slightly different but it might be worth a go. Have a look at this link, https://www.windowstechit.com/16465/fix-nvidia-control-panel/
So we must make sure that the Nvidia color profile doesn’t change even after a boot up. Also during running of the game, it can change the default profile. To avoid all these hiccups, we should stop the default “Calibration Loader Task” which initializes the Windows Color System at user logon.
Maybe it's a profile thing. Worth a look anyway you might find another setting somewhere else in there. Best fix will probably be adjusting on the monitor itself though.
Checked and my Calibration Loader Task was already disabled. Thanks.
Sorry, don't know what else to suggest short of posting screen shots of all the backglass screen specific settings from nvidia control panel for comparison.
Please upgrade to the latest version of PinballX and attach updated copies of your pinballx.ini and log.txt files. If the upgrade fixes the issue, please let us know.
