[RESOLVED] PinballX Doesn't start when i'm using two monitors
I have two monitors, extended. My main monitor is "2" and the secondary is "1"
I set up PinballX to display it'a main menu in "2" and the backglass previews to "1"
When i do so, the exe doesn't even start when i double click it. When i set the menu to "1" and backglass to "2" it won't start either.
The only way for the exe to open is to select BOTH as "2" or BOTH as "1", But the main menu always shows up in my main monitor "2" regardless what i choose. The backglass preview never shows up.
I'm using Windows 7 and the latest PinballX stable.
I use the 32 bit version of pinballx on my 64 bot windows. Can you give that a try ?
Not sure from the logfile, but looks like it misses a dll. Not sure if that is from  .net framework or that you enabled a plugin that is causing this
Ok, i re-installed PinballX and it seems fine now. Maybe i didn't install the previous one and just copied-pasted some files and that caused an issue.
@E36M3ZF sweet if its working ok can you please mark post [ RESOLVED ]
Thanks.
  • Draco1962 changed the title to [RESOLVED] PinballX Doesn't start when i'm using two monitors
  • Draco1962 locked this topic
