I've had a quick gander at how to get my xarcade stick configured for zinc with GameEx they all seem hugely complicated and time consuming. Is there any easy way of setting it up? Or does anyone have a configuration set up already for GameEx, Zinc and an Xarcade stick?
You need a controller plugin for Zinc. I've attached it here: inp_controller.zip
Unzip to your Zinc directory.
You open the "controller.cfg" with notepad and edit it to suit your X-Arcade button layout.
Emph
The X-Arcade is giving you grief?!? All I did with mine was plug and play and it works like a champ.
Isnt there a simpler way?
Once I got the Gameex buttons setup - I redefined MAME buttons within mame to match my layout
Then I used ZINCFE to redefine the buttons within ZINC
-I think I had to use the Winterblast plugin for some reason because of x-arcade
I had some probs setting up Zinc controllers. I found that i needed to download Winterblasts input plugin and that let me config the controls to what ever was attached. Hope this helps!
Specific solution is documented here in this thread.
http://www.gameex.info/forums/index.php?sh...ic=1156&hl=
