I have a GroovyMAME PC setup that uses an old ATI Radeon card w/ component transcoder that's connected to a Sony Trinitron consumer grade CRT TV
This PC has a barebones windows 7 Ultimate X64 with no updates because it's offline only. I've noticed after I installed Evo on this PC I get an error when I attempt to run Evo
E_NOINTERFACE The requested COM interface is not available (-2147467262)
Spoiler
************** Exception Text **************
SlimDX.DXGI.DXGIException: E_NOINTERFACE: The requested COM interface is not available (-2147467262)
   at SlimDX.Result.Throw[T](Object dataKey, Object dataValue)
   at SlimDX.Result.Record[T](Int32 hr, Boolean failed, Object dataKey, Object dataValue)
   at SlimDX.Result.Record[T](Int32 hr, Object dataKey, Object dataValue)
   at SlimDX.DXGI.Device2..ctor(IComObject device)
   at Headsoft.Tools.DirectWrite.b()
   at Headsoft.Tools.DirectWrite.Initialize(Size destSize, GDIFont gdiFont)
   at Headsoft.Engine.BitmapFont.DrawCharacterSet(Graphics graphics, Size destSize, GDIFont font, List`1 charList, Int32 lineHeight, Int32 baseLine, Color backgroundColor, FontNode fontNode, Boolean& useDirectWriteRendering)
   at Headsoft.Engine.BitmapFont.DrawCharacterSet(Color backgroundColor)
   at Headsoft.Engine.BitmapFont.GenerateBitmapFont(Color backgroundColor, Boolean preMultiplyAlpha)
   at Headsoft.Engine.BitmapFont.Initialize(String fontFolder, String fileName, Single sizeInPixels, FontStyle fontStyle, ColorNode textColor, ColorNode[] strokeColorArray, ShadowNode shadow, String charString)
   at Headsoft.Engine.BitmapFont.Initialize(String fontFolder, String fileName, Single sizeInPixels, FontStyle fontStyle, ColorNode textColor, ColorNode[] strokeColorArray, ShadowNode shadow)
   at Headsoft.Engine.TextObject.a(Device A_0)
   at Headsoft.Engine.TextObject.ResourceLoad(Device device)
   at Headsoft.Engine.Layout.ResourceLoad(Device device)
   at Main.OnLoadLayoutLoaded(Object sender, LayoutEventArgs e)
   at Headsoft.Engine.Layout.Create(LoadLayoutEventArgs loadLayoutEventArgs)
   at Headsoft.Engine.Layout.b(Object A_0, RunWorkerCompletedEventArgs A_1)
   at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
   at Headsoft.Engine.PsdParser.a(Object A_0, RunWorkerCompletedEventArgs A_1)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5692 (QFE.050727-5600)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
GameEx Evolution
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/GameEx%20Evolution.exe
System.Windows.Forms
    Win32 Version: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 2.0.50727.5668 (QFE.050727-5600)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 2.0.50727.5698 (QFE.050727-5600)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Headsoft.Engine
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/Headsoft.Engine.DLL
Headsoft.Tools
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/Headsoft.Tools.DLL
Headsoft.FrontEnd
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/Headsoft.FrontEnd.DLL
SlimDX
    Assembly Version: 2.0.13.43
    Win32 Version:
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/SlimDX.DLL
msvcm90
    Assembly Version: 9.0.30729.6161
    Win32 Version: 9.00.30729.6161
    CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251/msvcm90.dll
Headsoft.Image
    Assembly Version: 1.0.6559.1852
    Win32 Version:
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/Headsoft.Image.DLL
Headsoft.Video
    Assembly Version: 1.0.6537.39778
    Win32 Version:
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/Headsoft.Video.DLL
System.Xml
    Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
fzotwq8u
    Assembly Version: 0.0.0.0
System.Management
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
r0wr_vt4
qatikvbe
fihmyr69
htmf0y8s
Headsoft.DriveInfo
    Assembly Version: 1.0.6535.17563
    Win32 Version:
    CodeBase: file:///C:/GameEx%20Evolution/Bin/x64/Headsoft.DriveInfo.DLL
4a8xa7wq
cdxnpzxy
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
EVO error.txt
  • 4 weeks later...
