Hi Tom. :)
Having a couple problems...
My emulators (MAME included) are displaying their game lists until I scroll then they drop me an error message. This only happens on the first time I select an emulator. When I go back to the menu and go back in, they're fine.
I read something that was similar in the 6.62 bug thread, but it's back again.
Also, my snaps are sized way wrong in the game list (mostly too small - see thumbs below)
Perhaps it's related to the theme I'm using? Not sure. Insight would be cool.
The speed is friggin amazing! I'm happy to see the optimization is really moving along! A little nicer with every download. :)
There may be more things I haven't gotten to yet but I haven't got much time to tinker with it this weekend... I'll get back to ya.
G'day Tom / Team,
Also like Adultery experiencing a few problems with a recent update (Mine actually seemed to kick in around ??? 6.62 (Although you guys are producing so many its hard to tell!!!).
Effectively I have a few different things to Adultery:
Effectively I load up fine but are unable to use my back button, seemingly ALL my games have been moved into favorites and NONE of my "Category tab"s are selectable (For example if I select "Multimedia" (Is fine); "Jukebox" (Is fine) but trying to sort by Album / Title / Artist / etc doesnt work (Although I do seemingly get the cool new graphic effect.
I'm relatively new to GameEx so certainly CANT rule out that I have done something myself although I havent really made any great changes of late pre these errors commencing.
I have attached a copy of my error log below. Many thanks in advance for any assistance you guys can provide.
Cheers
Stuart
Adultery - my apologies for "hijacking" your thread. I just thought it might be easier for Tom / The Team if a ? similar problem with updates were placed together.
15:43:25.1 8/26/2006: GameEx: Version 6.65: Starting Log
15:43:25.1 8/26/2006: Operating System Platform: Win32NT
15:43:25.1 8/26/2006: Operating System Name: Windows XP
15:43:25.1 8/26/2006: Operating System Version: 5.1.2600
15:43:25.1 8/26/2006: Checking for versions of .net Framework installed
15:43:25.1 8/26/2006: .net Framework 1.1 Installed
15:43:25.1 8/26/2006: Running Randomize()
15:43:25.1 8/26/2006: Checking for applications to Launch On Startup
15:43:25.1 8/26/2006: Initialising Video/MNG DLL's
15:43:25.1 8/26/2006: Running Misc startup tasks
15:43:25.1 8/26/2006: Setting Menu types
15:43:25.1 8/26/2006: Opening Configuration File
15:43:25.1 8/26/2006: Getting Configuration Values
15:43:25.1 8/26/2006: Using Theme: Default - MCE Glossy
15:43:25.1 8/26/2006: Checking for alternate Image Directory for Theme: Default - MCE Glossy
15:43:25.1 8/26/2006: Launching HideOS.exe
15:43:25.1 8/26/2006: Hiding Taskbar
15:43:25.1 8/26/2006: Is Media Center running?
15:43:25.1 8/26/2006: Checking/Creating LCD Registry values
15:43:25.1 8/26/2006: Check Media Center Exit/Start Mode
15:43:25.1 8/26/2006: Media Center Mode 2
15:43:25.2 8/26/2006: Text/Language: English
15:43:25.2 8/26/2006: Applying Language/Text
15:43:25.3 8/26/2006: Snap Delay set to: 2
15:43:25.3 8/26/2006: Get other settings
15:43:25.3 8/26/2006: Set: Find emulator artwork on best match basis
15:43:25.4 8/26/2006: Start work for Form
15:43:25.4 8/26/2006: Getting Original Screen Size
15:43:25.4 8/26/2006: Loading ICON
15:43:25.4 8/26/2006: Initializing Component
15:43:25.4 8/26/2006: Initialising Bass Audio Library
15:43:25.6 8/26/2006: Loading default loading screen
15:43:25.6 8/26/2006: Using 2D Animations
15:43:25.6 8/26/2006: Using General Font: Trebuchet MS
15:43:25.6 8/26/2006: Using Title Font: Trebuchet MS
15:43:25.6 8/26/2006: Starting GameExtender Publisher
15:43:25.6 8/26/2006: Initialising DirectDraw
15:43:25.7 8/26/2006: Applying GameEx is Loading Image
15:43:25.7 8/26/2006: Creating DirectDraw Device
15:43:25.7 8/26/2006: Using Device: RADEON 9200 PRO Family (Microsoft Corporation)
15:43:25.7 8/26/2006: Setting Resolution to 800x600 32 bit color
15:43:27.2 8/26/2006: Creating DirectDraw Surfaces
15:43:27.2 8/26/2006: Creating Primary Surface - Full Screen Mode
15:43:27.3 8/26/2006: Creating Back Buffer
15:43:27.3 8/26/2006: Loading graphic surfaces
15:43:27.3 8/26/2006: Creating Surfaces Misc and Dialogs
15:43:27.4 8/26/2006: Creating Surface Volume
15:43:27.4 8/26/2006: Creating Surfaces Arrows
15:43:27.4 8/26/2006: Creating Surfaces GameEXlogo Text
15:43:27.4 8/26/2006: Creating Surfaces Toolbar
15:43:27.5 8/26/2006: Creating Surfaces Backgrounds
15:43:27.8 8/26/2006: Creating Surfaces Toolbar Controls
15:43:27.8 8/26/2006: Creating Surfaces GameEx Logo
15:43:27.8 8/26/2006: Creating Surfaces Home & Exit
15:43:27.8 8/26/2006: Creating Surfaces Snaps
15:43:27.8 8/26/2006: Creating Surfaces Menu and List Bars
15:43:27.9 8/26/2006: Creating Fonts
15:43:27.9 8/26/2006: Creating Menu Font
15:43:28.0 8/26/2006: Creating Game Font
15:43:28.1 8/26/2006: Creating Font Black
15:43:28.2 8/26/2006: Creating Font Black Small
15:43:28.4 8/26/2006: Creating Game Font Faded
15:43:28.5 8/26/2006: Creating Title Font
15:43:28.9 8/26/2006: Creating Control Panel Font
15:43:29.3 8/26/2006: Fonts Created Succesfully
15:43:29.4 8/26/2006: Initialising Windows Media Player Component
15:43:29.4 8/26/2006: MAME Path is: g:\mame32
15:43:29.4 8/26/2006: MAME EXE file is: Mame32.exe
15:43:29.4 8/26/2006: ROM Path is: G:\Mame32\roms
15:43:29.4 8/26/2006: Catver.ini is located at: F:\Program Files\GameEx\DATA\catver.ini
15:43:29.4 8/26/2006: controls.ini is located at: F:\Program Files\GameEx\data\controls.ini
15:43:29.4 8/26/2006: History.dat is located at: F:\Program Files\GameEx\DATA\history.dat
15:43:29.4 8/26/2006: nplayers.ini is located at: F:\Program Files\GameEx\DATA\nplayers.ini
15:43:29.4 8/26/2006: MAMEinfo.dat is located at: F:\Program Files\GameEx\DATA\mameinfo.dat
15:43:29.4 8/26/2006: Loading Controls.ini map file
15:43:29.4 8/26/2006: Snap Path is: g:\Mame32\snap
15:43:29.4 8/26/2006: AVI Snap Path: Not Found
15:43:29.4 8/26/2006: Flyer Path is: g:\Mame32\flyers
15:43:29.4 8/26/2006: Cabinet Path is: g:\Mame32\cabinets
15:43:29.4 8/26/2006: Title Path is: G:\Mame32\titles
15:43:29.4 8/26/2006: Panel Path: Not Found
15:43:29.4 8/26/2006: Icon Path is: g:\Mame32\icons
15:43:29.4 8/26/2006: Marquee Path is: G:\Mame32\marquees
15:43:29.5 8/26/2006: MAME CMD options: -triplebuffer -nowindow -joy
15:43:29.5 8/26/2006: Attempting to load game list
15:43:29.7 8/26/2006: Loading last used Game List
15:43:29.7 8/26/2006: Setting Music Volume
15:43:29.7 8/26/2006: Loading music
15:43:31.0 8/26/2006: Creating DirectSound Device
15:43:31.0 8/26/2006: Trying: Primary Sound Driver
15:43:31.0 8/26/2006: Loading Sound Files
15:43:31.0 8/26/2006: DirectSound Device Created Successfully
15:43:31.0 8/26/2006: Creating ICONS
15:43:31.0 8/26/2006: Restoring Cached ICONS from File
15:43:31.2 8/26/2006: Initialising DirectInput for Gamepad support
15:43:31.2 8/26/2006: Unable to create a joystick device
15:43:31.2 8/26/2006: Playing intro sound file
15:43:31.2 8/26/2006: Initializing MCE Remote
15:43:31.2 8/26/2006: Initialization OK! Starting GameEx!
15:43:31.2 8/26/2006: Testing Main Loop Once: Processing Frame
15:43:31.5 8/26/2006: Testing Main Loop Once: Main Loop ran successfully
15:43:35.0 8/26/2006: Loading Custom Emulators
15:47:31.2 8/26/2006: Starting Attract Mode
15:47:31.4 8/26/2006: Running: cmd.exe /c g: g:\mame32\Mame32.exe zupapa -rompath G:\Mame32\roms -triplebuffer -nowindow -joy -volume -32
15:49:36.7 8/26/2006: Running: cmd.exe /c g: g:\mame32\Mame32.exe liblrabl -rompath G:\Mame32\roms -triplebuffer -nowindow -joy -volume -32
15:51:40.5 8/26/2006: Running: cmd.exe /c g: g:\mame32\Mame32.exe hedpanic -rompath G:\Mame32\roms -triplebuffer -nowindow -joy -volume -32
15:53:30.7 8/26/2006: 21 Consecutive Exceptions Occured: Exiting
15:53:30.7 8/26/2006: Object reference not set to an instance of an object.
15:53:31.0 8/26/2006: at GameEx.GameEx.mainform.PlaySelectWAV()
15:53:31.0 8/26/2006: at GameEx.GameEx.mainform.processgamemenu()
15:53:31.0 8/26/2006: at GameEx.GameEx.mainform.DisplayFrame()
Funny thing is I was gonna put a line in my post about people posting problems in the same thread so Tom (who's obviously inherited twelve cases of Red Bull and a supply of NoDoz) can keep up with version-specific problems.
As far as 'thread hijacking' goes, I'm sure you'll find we're all pretty good people here and unless you're really asking for trouble (like GameEx bashing - especially X-Box 360 related!) you'll get along fine.
:D
Anyone else having problems with 6.65? Hijack away. :)
The first time i ran 665 after installation it actually prompted an error message and crashed. Launching it again (before i had a chance to save the log file of the crash) went through w/o issues.
At the main page, my emulators menu option was gone. When i go into the MAME section and then return back to the main page, the emulators option appears! I believe someone mentioned about this same issue in 6.62?
I am able to do the actions that stuartc88 seems to have problems with.
Have same problem with the size of snaps being real small but seems to be only with that theme your using Adultery, (Future Retro) other themes seem fine :blink:
I'm not sure if my problem is the same as the others. I installed GameEX 6.65 onto Vista build 5472 and whenever I exit out of a MAME or snes9x game, my navigation doesn't work correctly. The up or down arrow jumps either 2-3 positions on the menu. After awhile I get the following exception error:
Error in the application.
at Microsoft.DirectX.DirectDraw.Surface.Flip(Surface surafce, FlipFlag, flags)
Seems like the similar error as with the database problem that I reported before, however I did disabled this feature in configuration and MAME doesn't offer this feature, I don't think.
Good news though is that "My Games" label is showing in Vista Media Center. Yay!
p.s. Vista RC1 is expected within a week or so and will be the final public beta.
Having trouble taking snaps with 6.65, starts off ok but sometimes goes back to take snaps of games that already had snaps taken over and over again, also would pause sometimes and bring up windows display properties box, and after exiting from taking snaps then shutting down GameEx i get this error message
Was working fine till i upgraded from v6.56 :mellow:
We know you will, Tom...
You're just the man like that.
Round of applause for the hardest working cabinet pimp in FE business. :)
I had another bug to report but I'm thinking it may be theme related also, due to the fact I changed from Future Retro and it went away.
I'm gonna miss that theme... Any way to fix it? Or are my problems in fact GameEx related?
PS - Don't forget to grab you some sleep! :D
