[RESOLVED] Dolphin 5.0-8578 stopped working on GameEx 1.0.0.0
I haven't used my PC for a while. Everything was working correctly before. I tried to run a Gamecube game today. The screen flashed white, then went to black for a few seconds and returns to GameEx. I tried a few games all with the same outcome. Your help would be greatly appreciated. Thank you in advance.
log.txtFetching info...
GameEx.iniFetching info...
Dolphin.iniFetching info...
  On 8/23/2018 at 7:06 PM, Tom Speirs said:
Is it working outside of GameEx? Can you also try launching an unarchived file from GameEx. Its hard to troubleshoot when thry are compressed.
It is working outside. I can't get GameEx to list the extracted copy.
What I am saying its hard to troubleshoot as GameEx is extracting the ISOs. So please do a test emulator setup with an extracted ISO so I can figure out where it is failing.
Also the log shows the working path of dolphin.exe a bit strange. Its just showing G:. I cant remember if that's normal.
Can you post data\runitgame.bat please?
And is this for wii or gamecube because they have different working patths.
I understand what you are saying, Tom. I've run Dolphin from that drive for a long time without issue until now. You are right, I didn't catch that they were set up for different paths. A while back I updated Dolphin and it changed the folder. I must have done it for Wii and either not done it for Gamecube, or I just flubbed it. Thank you very much for your help. Sorry to waste your time.
You're forgiven. Now you gotta change your username. Lol
