Building my first cab and lovin it, made a million mistakes so far and figured most out using these threads.  Thanks a ton for everyone's help setting these games up and discussing each issue.  One nemesis remains that I haven't found the answer I need yet.  Please help if you can.
I have PBX running with both VPX and VPT tables enabled at this time.  PBX scrolls through all the games fine and loads up both types and plays great.  Exiting VPT tables works fine as well, it just pops back to the wheel to select the next table.  When trying to exit a VPX table however, the only way to exit the game is to hit "Q" and close the VPX game.  I can then hit ALT TAB and it will load back up PBX to select another table.  I've read a ton of threads where people map a different key and resolve the issue, but I've tried em all with no luck.
PBXRecorder also will not exit correctly (like VPT tables) after recording the vids on VPX tables.  The game stays running after the video is captured until you click the tray icon and close all screens.
Is there a setting I need to check for VPX that allows the game to close down or back out properly?  I had 10.4 running and this issue, just loaded the 10.5 stuff and it's still happening.
I apologize if the "fix" has been written somewhere and I missed it, please help here or direct me to a thread that addresses the issue I'm having.
Thanks a bunch!
Checked it and I wasn't running as admin, but that didn't fix the problem.  VPT tables back right out to PBX, and VPX tables still require me to hit Q and close VPX then it will reload PBX.
Please let me know any other thoughts, I'll try Anything!
Thanks!
You may want to attach copies of your pinballx.ini and log.txt files when reporting an error to the files can be reviewed.
Ok, here's the log, can't find the INI file though...  Let me know where it's at and I can post it as well.  The log shows below where I started PBX, opened South Park VPT and exited right back to PBX.  I then opened South Park VPX and it would not exit back to PBX.  I had to hit the Q button and it went to the VPX screen, I hit ALT TAB and it then loaded back up PBX.  I then loaded Space Invaders VPX and had to do the same process.  Finally I loaded Star Trek 25th VPT table and could back right out to PBX like I think It should work....  Such a simple thing it seems like, hopefully someone can see what I'm missing from the log below.  Once again, any help appreciated!  Thanks!
Spoiler
01:24:38.2  7/25/2018:  PinballX - Version 3.06
01:24:38.4  7/25/2018:  Windows 10 Pro 64-bit (7.9GB)
01:24:38.4  7/25/2018:  Loading Settings
01:24:38.4  7/25/2018:  Launching Startup Program: notepad.exe
01:24:38.4  7/25/2018:  \notepad.exe
01:24:38.5  7/25/2018:  Initialize Component
01:24:38.5  7/25/2018:  Initialize Display
01:24:40.0  7/25/2018:  Loading PlugIns
01:24:41.4  7/25/2018:  Created DirectX BackGlass Window
01:24:41.4  7/25/2018:  Created DirectX DMD Window
01:24:41.4  7/25/2018:  Looking for startup images
01:24:41.6  7/25/2018:  Testing Flash engine.
01:24:41.7  7/25/2018:  Hiding Cursor
01:24:41.7  7/25/2018:  Hiding Taskbar
01:24:41.8  7/25/2018:  Getting GPU Information
01:24:41.8  7/25/2018:  CPU:  AMD Athlon( tm ) X4 860K Quad Core Processor
01:24:41.8  7/25/2018:  GPU 1: NVIDIA GeForce GTX 670
01:24:41.8  7/25/2018:  Displays: 3
01:24:42.1  7/25/2018:  Load Game List
01:24:42.1  7/25/2018:  Loading Database: Visual Pinball
01:24:42.3  7/25/2018:  Loading Database: VPinballX
01:24:42.3  7/25/2018:  Finding and matching artwork and videos
01:24:43.1  7/25/2018:  Loading Game Statistics and Scores
01:24:43.1  7/25/2018:  Main display running full screen windowed.
01:24:43.2  7/25/2018:  Loading Surfaces
01:24:43.4  7/25/2018:  Finished Loading Surfaces
01:24:43.4  7/25/2018:  Initialize Audio
01:24:43.7  7/25/2018:  Set Keyboard Controls
01:24:43.7  7/25/2018:  Initialize Joystick
01:24:43.7  7/25/2018:  No Joysticks Attached
01:24:43.7  7/25/2018:  Started
01:25:09.9  7/25/2018:  Launch System
01:25:09.9  7/25/2018:  Waiting for threads
01:25:10.0  7/25/2018:  Disposing display
01:25:11.6  7/25/2018:  Writing ScreenRes.txt
01:25:11.6  7/25/2018:  C:\Visual Pinball\VPinball994.exe /play -"C:\Visual Pinball\Tables\South Park. vpt "
01:25:11.9  7/25/2018:  C:\PinballX\vpauto.exe
01:25:19.2  7/25/2018:  Hidden Visual Pinball Editor Window
01:25:20.9  7/25/2018:  Found PinMAME ROM: sprk_103.nv
01:25:20.9  7/25/2018:  Setting DMD position
01:25:54.5  7/25/2018:  Exit System Control Pressed
01:26:03.4  7/25/2018:  Created DirectX BackGlass Window
01:26:03.5  7/25/2018:  Created DirectX DMD Window
01:26:03.5  7/25/2018:  Main display running full screen windowed.
01:26:11.2  7/25/2018:  Launch System
01:26:11.2  7/25/2018:  Waiting for threads
01:26:11.4  7/25/2018:  Disposing display
01:26:12.9  7/25/2018:  Writing ScreenRes.txt
01:26:12.9  7/25/2018:  C:\Visual Pinball\VPinballX.exe /play -"C:\Visual Pinball\Tables\South Park 1.1. vpx "
01:26:16.8  7/25/2018:  C:\PinballX\vpauto.exe
01:26:30.9  7/25/2018:  Hidden Visual Pinball Editor Window
01:26:32.4  7/25/2018:  Found PinMAME ROM: sprk_103.nv
01:26:32.4  7/25/2018:  Setting DMD position
01:28:13.5  7/25/2018:  Exit System Control Pressed
01:28:20.1  7/25/2018:  Created DirectX BackGlass Window
01:28:20.2  7/25/2018:  Created DirectX DMD Window
01:28:20.2  7/25/2018:  Main display running full screen windowed.
01:28:32.1  7/25/2018:  Launch System
01:28:32.1  7/25/2018:  Waiting for threads
01:28:32.2  7/25/2018:  Disposing display
01:28:33.9  7/25/2018:  Writing ScreenRes.txt
01:28:33.9  7/25/2018:  C:\Visual Pinball\VPinballX.exe /play -"C:\Visual Pinball\Tables\Space Invaders (Bally 1979) VPX1. vpx "
01:28:34.4  7/25/2018:  C:\PinballX\vpauto.exe
01:28:50.1  7/25/2018:  Hidden Visual Pinball Editor Window
01:28:51.2  7/25/2018:  Found PinMAME ROM: spaceinb.nv
01:28:51.2  7/25/2018:  Setting DMD position
01:29:40.7  7/25/2018:  Exit System Control Pressed
01:29:47.3  7/25/2018:  Created DirectX BackGlass Window
01:29:47.3  7/25/2018:  Created DirectX DMD Window
01:29:47.4  7/25/2018:  Main display running full screen windowed.
01:30:10.6  7/25/2018:  Launch System
01:30:10.6  7/25/2018:  Waiting for threads
01:30:10.6  7/25/2018:  Disposing display
01:30:11.9  7/25/2018:  Writing ScreenRes.txt
01:30:11.9  7/25/2018:  C:\Visual Pinball\VPinball994.exe /play -"C:\Visual Pinball\Tables\Star Trek 25th Anniversary (Data East 1991). vpt "
01:30:11.1  7/25/2018:  C:\PinballX\vpauto.exe
01:30:18.3  7/25/2018:  Found PinMAME ROM: trek_201.nv
01:30:18.3  7/25/2018:  Setting DMD position
01:30:18.9  7/25/2018:  Hidden Visual Pinball Editor Window
01:30:23.5  7/25/2018:  Exit System Control Pressed
01:30:32.2  7/25/2018:  Created DirectX BackGlass Window
01:30:32.3  7/25/2018:  Created DirectX DMD Window
01:30:32.3  7/25/2018:  Main display running full screen windowed.
01:30:37.9  7/25/2018:  Exiting
01:30:37.9  7/25/2018:  Showing Taskbar
01:30:37.9  7/25/2018:  Unhiding Mouse Cursor
01:30:37.9  7/25/2018:  Disposing Plugins
01:30:37.9  7/25/2018:  Saving Settings
01:30:37.9  7/25/2018:  Bye
I think this might be the INI file, ( C:\Pinballx\Config ), hopefully somebody can see where I went wrong!
Spoiler
[Display]
Monitor=0
rotate=270
windowed=False
windowwidth=480
windowheight=270
windowx=461
windowy=207
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
FullScreenWindowed=False
WheelAutoCrop=False
ShowExitImage=True
[BackGlass]
monitor=1
x=0
y=0
width=1366
height=768
UseB2S=False
AutoPositionB2S=True
[DMD]
monitor=2
x=0
y=10
width=1440
height=400
AutoPositionPinMAME=True
HidePinMAME=False
UsePinMAME=True
[FileSystem]
EnableFileMatching=False
[Interface]
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
WheelOverlay=3
EnableDefaultFilters=True
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[Startup]
playsound=True
playvideo=True
StartWithWindows=No
[KeyCodes]
quit=9
left=160
right=161
select=13
rotate=82
pageleft=90
pageright=191
exitemulator=9
ingame=80
screenshot=83
screenshotbackglass=66
instructions=73
volumedown=109
volumeup=107
credit=53
plunger=13
launch=96
capturevideos=86
[JoyCodes]
quit=7
left=9
right=1
select=8
rotate=3
pageleft=4
pageright=5
exitemulator=7
ingame=13
instructions=14
Credit=11
Plunger=0
[Text]
Line1=Free Play
Line2=Press Start
Featuring=Featuring
Tables=Tables
PlayGame=Play Ball
Instructions=Instructions
Information=Information
Flyer=Flyer
Gameplay=Gameplay
Tutorial=Tutorial
ExitGame=Exit Game
ReturnToGame=Return to Game
Return=Return
Exit=Exit
Shutdown=Shutdown
[FuturePinball]
Enabled=False
WorkingPath=C:\PinballX\Future Pinball
TablePath=C:\PinballX\Future Pinball\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
FPRAMPath=C:\PinballX\Future Pinball\fpRAM
[VisualPinball]
WorkingPath=C:\Visual Pinball
Executable=VPinball994.exe
[ExitScreen]
EnableExit=True
EnableShutdown=True
ConfirmExitGameTimer=False
[StartupProgram]
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=False
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=2
ShowFor=60
MuteAudio=False
[System_1]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Minutes=10
[Login]
Enabled=False
[PinballFX2]
Enabled=False
WorkingPath=C:\PinballX\Pinball FX2
Executable=Pinball FX2.exe
Parameters=-applaunch 226980 [TABLEFILE]
Process=Pinball FX2.exe
Rotate=True
WaitFor=11
[Internal]
lastwheelcachematchsize=626423
lastselected=Star Trek Enterprise Limited Edition (Stern 2012) VPX GreatStar Trek Enterprise Limited Edition (Stern 2012) VPX GreatSystem_5
filter_year=
filter_company=
filter_custom=
filtername=Tables
lastwheelcachematchsize2=13309
filter_favorites=False
filter_lastplayed=False
filter_mostplayed=False
[PinballArcade]
Executable=steam.exe
Parameters=-applaunch 238260
Process=PinballArcade.exe
Enabled=False
[GameListManager]
onlinemode=false
[SetupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=Advanced
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=4
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=4
ShowPanel=True
FontSize=1
WindowState=Normal
WindowSize=1168, 809
WindowLocation=378, 51
[System_2]
Name=VPinball921
WorkingPath=C:\Program Files (x86)\Visual Pinball
TablePath=C:\Program Files (x86)\Visual Pinball\Tables
Executable=VPinball921.exe
Enabled=False
SystemType=1
[System_3]
Name=VPphysmod5
Executable=VPphysmod5.exe
Enabled=False
SystemType=0
[System_4]
Name=VPinball902
Enabled=False
SystemType=1
Executable=VPinball902.exe
[System_5]
Name=VPinballX
SystemType=1
Executable=VPinballX.exe
LaunchBeforeEnabled=False
[System_6]
Name=Physmod 5 updated
Executable=VPinball99_PhysMod5_Updated.exe
Enabled=False
SystemType=1
[RealDMD]
EnableColor=False
Color=ffff0000
[Plugin_1]
Enabled=False
Name=PlugInLED.dll
[Plugin_2]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_3]
Enabled=False
[Plugin_4]
Enabled=False
Name=Xpadder Plugin.dll
[Topper]
monitor=2
[System_7]
Name=VP99 Physmod5
Executable=VPinball99_PhysMod5.exe
Parameters=
Enabled=False
SystemType=1
[VideoCapture]
Seconds=60
UseGPU=True
KeysStartRecord=67
KeysEndRecord=88
SavePath=C:\Users\A person\Desktop\Wheel TBD
[PinballFX3]
Enabled=False
[frmInfo]
Size=378, 314
Location=510, 177
WindowState=Normal
  • 1 month later...
Problem solved, I've read it 100 times to run as administrator but it "wasn't" running as administrator...
Ha Lay Lew Ya!
Thanks for the help!
