[RESOLVED] PinballX 2.83 - Monitor display order not recognized
I had noted in another thread that I was having some issues with the displays upon adding a new monitor in a "topper" configuration.
Initially they displayed  Windows in this order:
1 - Topper (HDMI)
2 - Playfield (DVI-D)
3 - Backglass (DVI-I)
4 - DMD (USB)
I have since bought some adapters to compensate for Windows 10 and Nvidia not wanting to play nice with the identities.
I deleted the registration entries, etc. Below are the order of the monitors as recognized by both the GPU and Win 10:
GPU - EVGA NVIDIA GeForce GTX 660 - Supports 4 monitors
Monitor 1 (Playfield 27 inch) - BenQ GW2750H 1920 x 1080 @ 60 Hz
Monitor 2 (Backglass 23 inch) - Acer S231HL 1920 x 1080 @ 60 Hz
Monitor 3 (Topper) Samsung Syncmaster T22B350 1920 x 1080 @60 Hz
Monitor 4 (DMD USB Monitor - 7 inch ) - MYMO NAV0010 800 x 480
Unfortunately, PinballX does not want to play nice. Following is the display order I am getting now via PinballX
Monitor 1 (Playfield) - Right
Monitor 2 (Topper) - WRONG
Monitor 3 (DMD) - WRONG
Monitor 4 (Backglass ) - WRONG
Here is my pinballx.ini (apologies in advance for not attaching - but can't attach due to attachment space limitations imposed by the forum):
  Reveal hidden contents
Here is my log.txt file:
  • Draco1962 changed the title to PinballX 2.83 - Monitor displays not recognized
I finally got my 4 screen setup to work with PinballX.  It was not working correctly before, but I now have it working with PF = Displayport, Backglass =DisplayPort, DMD=Displayport, Topper = HDMI.  Windows sees screen numbers as PF=2, Back=3, DMD=4, Topper=1.  PinballX sees PF=1, Back=2, DMD=3, Topper=4.  Really hate how windows assign monitor numbers.  Hope my setup works for more than 1 week.  Good luck
I am concerned as PinballX used to follow the same identity order as the OS and GPU up until I added the Topper monitor, but as 0-3 instead of 1-4.
  • Draco1962 changed the title to [RESOLVED] PinballX 2.83 - Monitor display order not recognized
Lock this thread up for now. I do not recall having to do this in the past, but on a lark, I went into Windows Display Settings and stacked my monitors vertically in this order:
3 - Topper
4 - DMD
2 - Backglass
1 - Playfield
I applied the settings and worked fine, each monitor receiving the correct input. Damndest thing but at least it is fixed for now.
  • Thanks 1
