After I upgraded manually to GameEx 15.20, the video snaps - only mame - are not working anymore. I replaced the LAV codecs with no success. All other emu video snaps are working.
Also key settings not working as before. Is anything change with the database?
Any ideas?
Any ideas?
Hi. Where did the MAME videos originate from? How are the key settings not working?
Could you please post your log?
Attach Log.txt and gameex.ini files when reporting an issue. Yours may not be the same as what is being reported but your files may confirm for certain.
Dear Tom, I meanwhile upgraded to 15.22 - same issue. I also tried some other video codecs with no success. Videos play fine otuside Gameex. It is not only related to Mame, also my NES videos are not playing, gameboy videos are running well - seems to be a different sourcce/encoding. Can you please check, because in the old Gameex everything was running well! Thanks
Here is my log file:
Spoiler
08:13:57.65  31.03.2018:  Opening Configuration File
08:13:57.68  31.03.2018:  GameEx: Version 15.22: Starting Log
08:13:57.76  31.03.2018:  Windows 10 Pro 64-Bit
08:13:57.76  31.03.2018:  Aero running
08:13:57.78  31.03.2018:  Initializing Vista/Windows 7 volume control
08:13:57.78  31.03.2018:  Getting CPU and RAM info
08:13:57.79  31.03.2018:  Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz, 7885MB
08:13:57.79  31.03.2018:  3,09Ghz - 4 Cores or CPU's
08:13:57.79  31.03.2018:  Running Randomize()
08:13:57.00  31.03.2018:  Loading PlugIns
08:13:58.08  31.03.2018:  Checking for applications to Launch On Startup
08:13:58.08  31.03.2018:  Setting default net connection limit to 15
08:13:58.08  31.03.2018:  Running Misc startup tasks
08:13:58.08  31.03.2018:  Setting Menu types
08:13:58.09  31.03.2018:  Getting Configuration Values
08:13:58.09  31.03.2018:  Using Theme: Default - BlueEx - Arcade640x480
08:13:58.09  31.03.2018:  Checking for alternate Image Directory for Theme: Default - BlueEx - Arcade640x480
08:13:58.11  31.03.2018:  Launching HideOS.exe
08:13:58.11  31.03.2018:  Initialising Video/MNG DLL's
08:13:58.11  31.03.2018:  Arcade Mode is on
08:13:58.12  31.03.2018:  Hiding Taskbar
08:13:58.15  31.03.2018:  Is Media Center running?
08:13:58.15  31.03.2018:  Checking/Creating LCD Registry values
08:13:58.17  31.03.2018:  Check Media Center Exit/Start Mode
08:13:58.17  31.03.2018:  Media Center Mode 2
08:13:58.18  31.03.2018:  Video previews on. Warning: Only recommended on modern systems
08:13:58.18  31.03.2018:  Custom Keyboard Input enabled: Getting custom codes
08:13:58.18  31.03.2018:  Snap Delay set to: 3
08:13:58.20  31.03.2018:  Get other settings
08:13:58.20  31.03.2018:  Start work for Form
08:13:58.22  31.03.2018:  Getting Original Screen Size
08:13:58.22  31.03.2018:  Opening Database Connection
08:13:58.22  31.03.2018:  Data Source=C:\GameEx\DATA\data.db3;Pooling=true;FailIfMissing=true
08:13:58.31  31.03.2018:  Initializing Component
08:13:58.34  31.03.2018:  MAME Path is: D:\GameExFiles\Emulators\MAME
08:13:58.34  31.03.2018:  Model 3 Path Path is: D:\GameExFiles\Emulators\Supermodel
08:13:58.34  31.03.2018:  Model 2 Path Path Is:  D:\GameExFiles\Emulators\Sega model 2
08:13:58.36  31.03.2018:  Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
08:13:58.37  31.03.2018:  Model 2 EXE file is: emulator_multicpu.exe
08:13:58.39  31.03.2018:  Model 2 emulator with command line support detected
08:13:58.39  31.03.2018:  Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
08:13:58.39  31.03.2018:  MAME EXE file is: mamearcade64.exe
08:13:58.44  31.03.2018:  ROM Path is: D:\Arcade\Mame\roms
08:13:58.44  31.03.2018:  Catver.ini is located at: C:\GameEx\DATA\catver.ini
08:13:58.44  31.03.2018:  controls.ini is located at: C:\GameEx\DATA\controls.ini
08:13:58.48  31.03.2018:  History.dat is located at: C:\GameEx\DATA\history.dat
08:13:58.50  31.03.2018:  nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
08:13:58.50  31.03.2018:  command.dat is located at: C:\GameEx\DATA\command.dat
08:13:58.50  31.03.2018:  MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
08:13:58.51  31.03.2018:  Loading Controls.ini map file
08:13:58.53  31.03.2018:  Snap Path is: D:\GameExFiles\Media\MAME\SNAP
08:13:58.54  31.03.2018:  Database Snap Path: Not Found
08:13:58.54  31.03.2018:  Background Snap Path: Not Found
08:13:58.54  31.03.2018:  AVI Snap Path is: D:\GameExFiles\Media\MAME\VIDEOS
08:13:58.56  31.03.2018:  Flyer Path is: D:\GameExFiles\Media\MAME\FLYERS
08:13:58.58  31.03.2018:  Cabinet Path is: D:\GameExFiles\Media\MAME\CABINETS
08:13:58.58  31.03.2018:  Cabinet 3D Path is: D:\GameExFiles\Media\MAME\3DCabinets
08:13:58.59  31.03.2018:  Title Path is: D:\GameExFiles\Media\MAME\TITLES
08:13:58.59  31.03.2018:  Title Path is: D:\GameExFiles\Media\MAME\Logos
08:13:58.61  31.03.2018:  PCB Path is: D:\GameExFiles\Media\MAME\PCB
08:13:58.62  31.03.2018:  Artwork Preview Path is: D:\GameExFiles\Media\MAME\ArtPreview
08:13:58.62  31.03.2018:  Panel Path is: D:\GameExFiles\Media\MAME\CPANEL
08:13:58.64  31.03.2018:  Manual Path is: D:\GameExFiles\Media\MAME\MANUALS
08:13:58.65  31.03.2018:  Icon Path is: D:\GameExFiles\Media\MAME\ICONS
08:13:58.65  31.03.2018:  Marquee Path is: D:\GameExFiles\Media\MAME\MARQUEES
08:13:58.67  31.03.2018:  Applying Language/Text
08:13:58.67  31.03.2018:  Text/Language: English
08:13:58.68  31.03.2018:  Loading Language/Text
08:13:58.70  31.03.2018:  Loading Addins
08:13:58.72  31.03.2018:  Using 2D Animations
08:13:58.72  31.03.2018:  Retrieving resolution setting
08:13:58.73  31.03.2018:  Using General Font: Trebuchet MS
08:13:58.73  31.03.2018:  Using Title Font: Joystix
08:13:58.75  31.03.2018:  GameEx will try to reduce CPU usage
08:13:58.81  31.03.2018:  Initialising Direct3D
08:13:59.01  31.03.2018:  Mouse Input is disabled
08:13:59.01  31.03.2018:  Applying GameEx is Loading Image
08:13:59.01  31.03.2018:  Setting Resolution to 800x600 32 bit color
08:13:59.03  31.03.2018:  Creating Surfaces
08:13:59.56  31.03.2018:  Creating Back Buffer
08:13:59.56  31.03.2018:  Loading graphic Surfaces
08:13:59.58  31.03.2018:  Display is running at: 800x600 32bit color, 30hz
08:13:59.58  31.03.2018:  Adapter: Ultimarc ArcadeVGA5000
08:13:59.59  31.03.2018:  Max texture size: 16384x16384
08:13:59.59  31.03.2018:  Available texture memory: 4090MB
08:13:59.62  31.03.2018:  Available video memory: 2300MB
08:13:59.70  31.03.2018:  Initialising Bass Audio Library
08:13:59.84  31.03.2018:  Creating Surfaces Misc and Dialogs
08:13:59.88  31.03.2018:  Creating Surfaces Volume
08:13:59.89  31.03.2018:  Creating Surfaces Arrows
08:13:59.90  31.03.2018:  Creating Surfaces GameEXlogo Text
08:13:59.91  31.03.2018:  Creating Surfaces Toolbar
08:13:59.93  31.03.2018:  Creating Surfaces Toolbar Controls
08:13:59.99  31.03.2018:  Creating Surfaces Backgrounds
08:13:59.99  31.03.2018:  Creating Surfaces GameEx Logo
08:14:00.02  31.03.2018:  Creating Surface Unselected
08:14:00.03  31.03.2018:  Creating Surfaces Home & Exit
08:14:00.06  31.03.2018:  Creating Surfaces Snaps
08:14:00.08  31.03.2018:  Creating Surfaces Menu and List Bars
08:14:00.64  31.03.2018:  Creating Fonts
08:14:00.65  31.03.2018:  Creating Game Font
08:14:00.87  31.03.2018:  Creating Game Font Faded
08:14:01.19  31.03.2018:  Creating Title Font
08:14:01.21  31.03.2018:  Restoring Title Font From Cache
08:14:01.24  31.03.2018:  Creating Menu Font
08:14:01.62  31.03.2018:  Creating Font Black
08:14:01.65  31.03.2018:  Creating Font Black Small
08:14:01.69  31.03.2018:  Fonts Created Succesfully
08:14:01.75  31.03.2018:  7MB Video Memory Used
08:14:01.76  31.03.2018:  Initial Emulator Load
08:14:01.79  31.03.2018:  Loading Custom Emulators
08:14:01.80  31.03.2018:  Loading Emulator 2: Atari 2600
08:14:01.83  31.03.2018:  Loading Emulator 3: Game Boy
08:14:01.85  31.03.2018:  Loading Emulator 5: Game Boy Color
08:14:01.86  31.03.2018:  Loading Emulator 6: Nintendo NES
08:14:01.87  31.03.2018:  Loading Emulator 7: Nintendo SNES
08:14:01.90  31.03.2018:  Loading Emulator 8: Sega Game Gear
08:14:01.94  31.03.2018:  Loading Emulator 9: Sega Genesis
08:14:01.96  31.03.2018:  Loading Emulator 10: Sega Master System
08:14:01.96  31.03.2018:  Loading Emulator 11: Sega Model 2
08:14:01.99  31.03.2018:  Loading Emulator 12: Sega Model 3
08:14:01.00  31.03.2018:  Loading Emulator 17: NEC TurboGrafx-16
08:14:02.03  31.03.2018:  Checking if Steam enabled
08:14:02.03  31.03.2018:  Steam support is turned off in configuration.
08:14:02.12  31.03.2018:  Checking if Origin enabled
08:14:02.12  31.03.2018:  Origin support is turned off in configuration.
08:14:02.13  31.03.2018:  Checking if Uplay enabled
08:14:02.14  31.03.2018:  UPlay support is turned off in configuration.
08:14:02.33  31.03.2018:  Using Ultimarc AradeVGA
08:14:02.34  31.03.2018:  MAME CMD options: -nowindow -skip_gameinfo -mouse -multimouse -lightgun -offscreen_reload
08:14:02.35  31.03.2018:  Cannot Load Play List. Check Path and filename
08:14:02.36  31.03.2018:  Gamepad/Joystick disabled
08:14:02.36  31.03.2018:  Initialising Keyboard support
08:14:02.37  31.03.2018:  Loading Start Page
08:14:02.43  31.03.2018:  Initializing MCE Remote
08:14:02.44  31.03.2018:  Playing intro sound file
08:14:02.47  31.03.2018:  Initialization OK! Starting GameEx!
08:14:02.48  31.03.2018:  Testing Main Loop Once: Processing Frame
08:14:02.66  31.03.2018:  Testing Main Loop Once: Main Loop ran successfully
08:14:06.66  31.03.2018:  Attempting to load game list
08:14:06.00  31.03.2018:  Validating: Emulator_2: Snap Path: C:\Emulation\Assets\Atari 2600\Snaps
08:14:07.00  31.03.2018:  Validating: Emulator_2: Video Snap Path: D:\Arcade\Media\Atari 2600\Video
08:14:07.06  31.03.2018:  Validating: Emulator_2: Control Panel Path: C:\Emulation\Assets\Atari 2600\Controls
08:14:07.06  31.03.2018:  Validating: Emulator_2: Database: [Console] Atari 2600
08:14:07.07  31.03.2018:  Validating: Emulator_2: Title Snap Path: C:\Emulation\Assets\Atari 2600\Titles
08:14:07.07  31.03.2018:  Validating: Emulator_2: Box Art Path: C:\Emulation\Assets\Atari 2600\Boxes
08:14:07.08  31.03.2018:  Validating: Emulator_2: Cart Art Path: C:\Emulation\Assets\Atari 2600\Cartridges
08:14:07.08  31.03.2018:  Validating: Emulator_2: Manual Path: C:\Emulation\Assets\Atari 2600\Manuals
08:14:07.08  31.03.2018:  Validating: Emulator_3: Snap Path: D:\GameExFiles\Media\GameBoy\snap
08:14:07.11  31.03.2018:  Validating: Emulator_3: Video Snap Path: D:\Arcade\Media\Nintendo Game Boy\Video
08:14:07.13  31.03.2018:  Validating: Emulator_3: Control Panel Path: C:\Emulation\Assets\Nintendo Game Boy\Controls
08:14:07.14  31.03.2018:  Validating: Emulator_3: Database: [Handheld] Nintendo Game Boy
08:14:07.14  31.03.2018:  Validating: Emulator_3: Title Snap Path: D:\GameExFiles\Media\GameBoy\title
08:14:07.14  31.03.2018:  Validating: Emulator_3: Box Art Path: D:\GameExFiles\Media\GameBoy\box
08:14:07.15  31.03.2018:  Validating: Emulator_3: Cart Art Path: D:\GameExFiles\Media\GameBoy\cart
08:14:07.16  31.03.2018:  Validating: Emulator_3: Manual Path: D:\GameExFiles\Media\GameBoy\manual
08:14:07.16  31.03.2018:  Validating: Emulator_5: Snap Path: D:\GameExFiles\Media\GameBoy Color\snap
08:14:07.18  31.03.2018:  Validating: Emulator_5: Video Snap Path: D:\GameExFiles\Media\GameBoy Color\video
08:14:07.18  31.03.2018:  Validating: Emulator_5: Control Panel Path: C:\Emulation\Assets\Nintendo Game Boy Color\Controls
08:14:07.19  31.03.2018:  Validating: Emulator_5: Database: [Handheld] Nintendo Game Boy Color
08:14:07.19  31.03.2018:  Validating: Emulator_5: Title Snap Path: D:\GameExFiles\Media\GameBoy Color\title
08:14:07.20  31.03.2018:  Validating: Emulator_5: Box Art Path: D:\GameExFiles\Media\GameBoy Color\box
08:14:07.20  31.03.2018:  Validating: Emulator_5: Cart Art Path: D:\GameExFiles\Media\GameBoy Color\cart
08:14:07.20  31.03.2018:  Validating: Emulator_5: Manual Path: D:\GameExFiles\Media\GameBoy Color\manual
08:14:07.21  31.03.2018:  Validating: Emulator_6: Snap Path: D:\GameExFiles\MEDIA\Nintendo NES\\-Matched-\SNAP
08:14:07.24  31.03.2018:  Validating: Emulator_6: Video Snap Path: D:\GameExFiles\MEDIA\Nintendo NES\\-Matched-\Video
08:14:07.25  31.03.2018:  Validating: Emulator_6: Database: [Console] Nintendo NES
08:14:07.25  31.03.2018:  Validating: Emulator_6: Title Snap Path: D:\GameExFiles\MEDIA\Nintendo NES\\-Matched-\TITLE
08:14:07.26  31.03.2018:  Validating: Emulator_6: Box Art Path: D:\GameExFiles\MEDIA\Nintendo NES\\-Matched-\BOX
08:14:07.26  31.03.2018:  Validating: Emulator_6: Cart Art Path: D:\GameExFiles\MEDIA\Nintendo NES\\-Matched-\Cart
08:14:07.26  31.03.2018:  Validating: Emulator_6: Manual Path: D:\GameExFiles\MEDIA\Nintendo NES\\-Matched-\Manual
08:14:07.27  31.03.2018:  Validating: Emulator_7: Snap Path: D:\GameExFiles\MEDIA\Nintendo SNES\\-Matched-\SNAP
08:14:07.31  31.03.2018:  Validating: Emulator_7: Video Snap Path: D:\GameExFiles\MEDIA\Nintendo SNES\\-Matched-\Video
08:14:07.32  31.03.2018:  Validating: Emulator_7: Database: [Console] Nintendo SNES
08:14:07.32  31.03.2018:  Validating: Emulator_7: Title Snap Path: D:\GameExFiles\MEDIA\Nintendo SNES\\-Matched-\TITLE
08:14:07.32  31.03.2018:  Validating: Emulator_7: Box Art Path: D:\GameExFiles\MEDIA\Nintendo SNES\\-Matched-\BOX
08:14:07.33  31.03.2018:  Validating: Emulator_7: Cart Art Path: D:\GameExFiles\MEDIA\Nintendo SNES\\-Matched-\Cart
08:14:07.33  31.03.2018:  Validating: Emulator_7: Manual Path: D:\GameExFiles\MEDIA\Nintendo SNES\\-Matched-\Manual
08:14:07.34  31.03.2018:  Validating: Emulator_8: Snap Path: D:\GameExFiles\Media\Sega Game Gear\Snaps
08:14:07.36  31.03.2018:  Validating: Emulator_8: Video Snap Path: D:\Arcade\Media\Sega Game Gear\Video
08:14:07.38  31.03.2018:  Validating: Emulator_8: Control Panel Path: D:\GameExFiles\Media\Sega Game Gear\Controls
08:14:07.38  31.03.2018:  Validating: Emulator_8: Database: [Handheld] Sega Game Gear
08:14:07.39  31.03.2018:  Validating: Emulator_8: Title Snap Path: D:\GameExFiles\Media\Sega Game Gear\Titles
08:14:07.39  31.03.2018:  Validating: Emulator_8: Box Art Path: D:\GameExFiles\Media\Sega Game Gear\Boxes
08:14:07.40  31.03.2018:  Validating: Emulator_8: Cart Art Path: D:\GameExFiles\Media\Sega Game Gear\Cartridges
08:14:07.40  31.03.2018:  Validating: Emulator_8: Manual Path: D:\GameExFiles\Media\Sega Game Gear\Manuals
08:14:07.40  31.03.2018:  Validating: Emulator_9: Snap Path: D:\GameExFiles\Media\Sega Genesis\Snaps
08:14:07.42  31.03.2018:  Validating: Emulator_9: Video Snap Path: D:\Arcade\Media\Sega Genesis\Video
08:14:07.44  31.03.2018:  Validating: Emulator_9: Control Panel Path: D:\GameExFiles\Media\Sega Genesis\Controls
08:14:07.44  31.03.2018:  Validating: Emulator_9: Database: [Console] Sega Genesis
08:14:07.44  31.03.2018:  Validating: Emulator_9: Title Snap Path: D:\GameExFiles\Media\Sega Genesis\Titles
08:14:07.45  31.03.2018:  Validating: Emulator_9: Box Art Path: D:\GameExFiles\Media\Sega Genesis\Boxes
08:14:07.45  31.03.2018:  Validating: Emulator_9: Cart Art Path: D:\GameExFiles\Media\Sega Genesis\Cartridges
08:14:07.46  31.03.2018:  Validating: Emulator_9: Manual Path: D:\GameExFiles\Media\Sega Genesis\Manuals
08:14:07.46  31.03.2018:  Validating: Emulator_10: Snap Path: D:\GameExFiles\Media\Sega Master System\Snaps
08:14:07.49  31.03.2018:  Validating: Emulator_10: Video Snap Path: D:\Arcade\Media\Sega Master System\Video
08:14:07.51  31.03.2018:  Validating: Emulator_10: Control Panel Path: D:\GameExFiles\Media\Sega Master System\Controls
08:14:07.51  31.03.2018:  Validating: Emulator_10: Database: [Console] Sega Master System
08:14:07.52  31.03.2018:  Validating: Emulator_10: Title Snap Path: D:\GameExFiles\Media\Sega Master System\Titles
08:14:07.52  31.03.2018:  Validating: Emulator_10: Box Art Path: D:\GameExFiles\Media\Sega Master System\Boxes
08:14:07.52  31.03.2018:  Validating: Emulator_10: Cart Art Path: D:\GameExFiles\Media\Sega Master System\Cartridges
08:14:07.53  31.03.2018:  Validating: Emulator_10: Manual Path: D:\GameExFiles\Media\Sega Master System\Manuals
08:14:07.53  31.03.2018:  Validating: Emulator_11: Snap Path: D:\GameExFiles\Media\Sega model 2\snap
08:14:07.57  31.03.2018:  Validating: Emulator_11: Video Snap Path: D:\GameExFiles\Media\Sega model 2\video
08:14:07.57  31.03.2018:  Validating: Emulator_11: Control Panel Path: C:\Emulation\Assets\Arcade\Model2\Controls
08:14:07.58  31.03.2018:  Validating: Emulator_11: Database: [Arcade] Sega Model 2
08:14:07.58  31.03.2018:  Validating: Emulator_11: Title Snap Path: D:\GameExFiles\Media\Sega model 2\snap
08:14:07.58  31.03.2018:  Validating: Emulator_11: Box Art Path: D:\GameExFiles\Media\Sega model 2\box
08:14:07.60  31.03.2018:  Validating: Emulator_11: Cart Art Path: D:\GameExFiles\Media\Sega model 2\cart
08:14:07.60  31.03.2018:  Validating: Emulator_11: Manual Path: D:\GameExFiles\Media\Sega model 2\manual
08:14:07.60  31.03.2018:  Validating: Emulator_12: Snap Path: D:\GameExFiles\Media\Sega Model 3\Snaps
08:14:07.61  31.03.2018:  Validating: Emulator_12: Video Snap Path: D:\Arcade\Media\Sega Model 3\Video
08:14:07.61  31.03.2018:  Validating: Emulator_12: Control Panel Path: D:\GameExFiles\Media\Sega Model 3\Controls
08:14:07.62  31.03.2018:  Validating: Emulator_12: Database: [Arcade] Sega Model 3
08:14:07.62  31.03.2018:  Validating: Emulator_12: Title Snap Path: D:\GameExFiles\Media\Sega Model 3\Titles
08:14:07.63  31.03.2018:  Validating: Emulator_12: Box Art Path: D:\GameExFiles\Media\Sega Model 3\Boxes
08:14:07.63  31.03.2018:  Validating: Emulator_12: Cart Art Path: D:\GameExFiles\Media\Sega Model 3\Cartridges
08:14:07.64  31.03.2018:  Validating: Emulator_12: Manual Path: D:\GameExFiles\Media\Sega Model 3\Manuals
08:14:07.64  31.03.2018:  Validating: Emulator_17: Snap Path: D:\GameExFiles\Media\NEC TurboGrafx-16\Snaps
08:14:07.67  31.03.2018:  Validating: Emulator_17: Video Snap Path: D:\Arcade\Media\NEC Turbografx-16\Video
08:14:07.69  31.03.2018:  Validating: Emulator_17: Control Panel Path: D:\GameExFiles\Media\NEC TurboGrafx-16\Controls
08:14:07.69  31.03.2018:  Validating: Emulator_17: Database: [Console] NEC TurboGrafx-16
08:14:07.70  31.03.2018:  Validating: Emulator_17: Title Snap Path: D:\GameExFiles\Media\NEC TurboGrafx-16\Titles
08:14:07.70  31.03.2018:  Validating: Emulator_17: Box Art Path: D:\GameExFiles\Media\NEC TurboGrafx-16\Boxes
08:14:07.70  31.03.2018:  Validating: Emulator_17: Cart Art Path: D:\GameExFiles\Media\NEC TurboGrafx-16\Cartridges
08:14:07.71  31.03.2018:  Validating: Emulator_17: Manual Path: D:\GameExFiles\Media\NEC TurboGrafx-16\Manuals
08:14:07.74  31.03.2018:  Restoring Emulator from Cache: 2
08:14:07.84  31.03.2018:  Restoring Emulator Database From Cache: 2
08:14:08.23  31.03.2018:  Restoring Emulator from Cache: 3
08:14:08.30  31.03.2018:  Restoring Emulator Database From Cache: 3
08:14:08.77  31.03.2018:  Restoring Emulator from Cache: 5
08:14:08.79  31.03.2018:  Restoring Emulator Database From Cache: 5
08:14:09.16  31.03.2018:  Restoring Emulator from Cache: 6
08:14:09.19  31.03.2018:  Restoring Emulator Database From Cache: 6
08:14:09.72  31.03.2018:  Restoring Emulator from Cache: 7
08:14:09.77  31.03.2018:  Restoring Emulator Database From Cache: 7
08:14:10.58  31.03.2018:  Restoring Emulator from Cache: 8
08:14:10.60  31.03.2018:  Restoring Emulator Database From Cache: 8
08:14:10.93  31.03.2018:  Restoring Emulator from Cache: 9
08:14:10.96  31.03.2018:  Restoring Emulator Database From Cache: 9
08:14:11.31  31.03.2018:  Restoring Emulator from Cache: 10
08:14:11.38  31.03.2018:  Restoring Emulator Database From Cache: 10
08:14:11.67  31.03.2018:  Restoring Emulator Database From Cache: 11
08:14:11.98  31.03.2018:  Restoring Emulator from Cache: 12
08:14:12.00  31.03.2018:  Restoring Emulator Database From Cache: 12
08:14:12.29  31.03.2018:  Restoring Emulator Database From Cache: 17
08:14:13.04  31.03.2018:  Restoring Cached ICONS from File
08:14:25.53  31.03.2018:  Exiting GameEx!
08:14:25.54  31.03.2018:  Closing HideOS.exe
08:14:25.73  31.03.2018:  Disposing all videos
08:14:25.75  31.03.2018:  Deleting temporary Karaoke videos
08:14:25.76  31.03.2018:  Disposing Image List
08:14:25.76  31.03.2018:  Disposing Fonts
08:14:25.77  31.03.2018:  Disposing Surfaces
08:14:25.78  31.03.2018:  Saving Settings
08:14:25.79  31.03.2018:  Saving Settings
08:14:25.80  31.03.2018:  Shutting down Bass
08:14:25.85  31.03.2018:  Disposing Plugins
08:14:25.87  31.03.2018:  Disposing Plugins
08:14:25.87  31.03.2018:  Closing database connection
08:14:25.88  31.03.2018:  Checking for applications to Launch On Exit
08:14:25.90  31.03.2018:  Bye
Edited by tthurman
Hi, again, where did the videos come from? Maybe upload a couple that are not working? Do you have codecs installed?
I notice the ArcadeVGA and that you are running at 30hz. What kind of display do you have?
Dear Tom,
unfortunately the update GameEx install is also not working. I use the latest LAV codecs on my system, and everything worked fine before your latest update. I got all the media files on a harddisk from a fried, so I do not know the source or the capturing parameters exactly. I have a Sega Naomi cabinet with with Sanwa 29E31S (I guess multisnyc) monitor. The videos are running, if I install a player (e.g. X-Codec pack). I have attached two videos from my mae folder. The mame games are running fine (emulator setting still OK). I had problems with the key setting to control the main menu. All settings were as before, but the buttons and the second joystick did not work. The first joysitck is also installed as "Joystick" instead of key mapping. This worked!
Edit: I tried "Windows Media Player" here I find the same issue with the videos: sound yes, video no. But X-Codec player is working fine. Maybe the video format is outdated?
Another solution is, that you give me GameEx 2.50, that worked like a charm. Unfortunately, I have deleted the setup.
Thanks for your help!
Torsten
3bagflvt.mp4
3stooges.mp4
X-Codec pack is probably your issue. It installs codecs on your system and may stop Lav from working.
The issue is almost certainly codec related. I know where those videos came from. They should play fine.
The latest release should fix the keyboard issue. It was released after.
Dear Tom, thank you very much. I installed the lastest version - the keys are working again, but the codecs not. I deinstalled all codec packs on my machine and searched with codec sniper. There was nothing unusual. I cleaned up the registry. Still no success. Everything came with you last update. None of my videos are working. Sorry!
Hey guys, big GameEx fan here, thanks very much Tom!
I've been having a similar problem since the last update but it was also a big Windows update time for this computer too.  I'm using GameEx Arcade and everything else is totally normal and working a-ok as usual except for the Mame .mp4 videos.  I don't think it's a GameEx thing though, I can't get them to work in Windows Media Player either, just like above I get audio but a black screen, same as inside GameEx Arcade.  All the other console's videos are working normally, it's just the Mame .mp4 that are black with audio.
Uninstalled and updated the LAV codecs, tried the Shark ones, tried the Windows Media Pack ones, can't get the .mp4 videos to work in Media Player. They play fine in VLC.  And they played fine in GameEx for the last year too.  In December there was a GameEx update that did a similar thing, black videos with audio for the Mame snaps, but then a few days later the subsequent update fixed it.
But then yesterday I did a big many months overdue Windows update along with the GameEx Arcade update and probably hosed up other stuff on this ol' Dell..
I feel like it's a codec thing though.. any other tips to try?
PS - Thanks very much to Draco1962 for the awesome Arcade theme, it's perfect, couldn't ask for a better background for my arcade!
  • Thanks 1
  • Haha 1
Hi Tom, I went back to the old install you provided and everything runs fine. So it is NOT a windows issue.
Hi, I wouldn't say that. We just don't know at this point.
  • Haha 1
However, thanks for your help. I have a working version of GameEx.
Those particular videos do require codecs and your right that windows media player does not play them but they should work fine if you have codecs installed with GameEx. There should be no issue with them as long as codecs are installed. I really don't know what it could be at this point but can confirm the op was using the same videos. You should post your log anyway though.
4 hours ago, RichardH754 said:
Same problem for me, everything after 15.20 does not play video snaps, but before does?
If you are having the same issue, can you attach a copy of your gameex.ini file? Also, Tom will need to know what codecs you have installed and the format/source of your video snaps.
Hi, just saying it does not work for you does not help to fix the issue. We already know a few folks have an issue. Please try to add additional detail and files if you have a problem.
Thanks.
Tom.
I released a new version today that does fix videos not playing for one person. I`m not convinced its the same issue but please try it out and let me know.
Thanks.
Tom.
