[RESOLVED] Why wont controllers work for MAME, through Gameex?
All of a sudden, the controllers wont work for MAME when launched through Gameex. They work fine when played through MAME direct, but not through Gameex.
The controllers work fine within Gameex for browsing, but go dead when game is launched.
Any ideas?
What controllers?
If you've recently updated GameEx, download the full installer and install GameEx over itself.  Your settings shouldn't be impacted, but backups are always a good idea if you're worried.
If that doesn't do it, you should post your log and ini right after experience the problem.
Do you have more than one Mame executable set up on your PC?
Any chance you are using one to test outside Mame and another configured in GameEx?
Well it was operator error.  I duplicated MAME to troubleshoot another controller issue and was pointing to the wrong .exe.
guys. :)
