ro2013 Posted December 10, 2017 Posted December 10, 2017 I too am using Windows 10 and having this same issue where my PinDMD 3 works fine in game but nothing shows up when I use Pinball X. Should I at least be seeing a Pinball X graphic? Has anyone found out the issue?
Tom Speirs Posted December 10, 2017 Posted December 10, 2017 Hard to know without seeing your log and pinballx.ini A common problem is a bug in older versions of Windows 10 that affected videos playing in a whole load of applications. Then the other thing is LAV codecs are not installed.
emalave Posted June 28, 2018 Posted June 28, 2018 Hi, I have a Pindmd3 and the real images and videos have stopped showing on my pindmd3. My logs , pinballx ini and settings are attached. Any help would be great! Thanks! log.txt [SETTINGS].log PinballX.ini
GAH1068 Posted June 28, 2018 Posted June 28, 2018 I have a PinDMDV3 and everything is working fine for me so sounds like a DLL issue. Try renaming the PinDMD.Dll so it is not used and make sure you are using dmddevice.dll with the .ini file set. 1
Pablo Smiraglia Posted July 4, 2018 Posted July 4, 2018 On 6/28/2018 at 11:09 AM, GAH1068 said: I have a PinDMDV3 and everything is working fine for me so sounds like a DLL issue. Try renaming the PinDMD.Dll so it is not used and make sure you are using dmddevice.dll with the .ini file set. can you describe date and size of xdmd.dll, xdmnative.dll, dmdvevide.dll you are using ? This is a lingering issue I have with pinballx. Best I get now is the DMD works in PBX at boot, but never again after I launch a table. The Pindmdv3 works well with a variety of emulators and drivers: VPx/9 with dmddevice.dll from freezy, UltraDMD, FX2/3 with dmdext, etc. There seems to be a dll that fails to load when exiting the emulators. Logs do not even show an attempt to start the external DMD.
GAH1068 Posted July 4, 2018 Posted July 4, 2018 @Pablo Smiraglia - see below. I just took this from my system a few moments ago. I have the generic pinballX video running on my PinDMDV3 when I am in Pinballx. I have never got around to doing dmd videos for the games, it is pretty low priority for me. I have no issues either running dmdext.exe (FX3, PBA, Timeshock, Pinball Wicked) or using the built-in DMDDevice.Dll for VP9 and VPX tables. In PinballX Game manager make sure to check Disable DMD for the games otherwise your will get the issue you are reporting. Up until a few versions ago that check mark really didn't appear to do anything. Now, unless I check it in game manager the PinballX default DMD would be displayed and then the in-game one would not work. This might be your problem. PinballX Directory: XDMD.DLL 5/23/18 8:27PM XDMDNative.DLL 5/23/18 8:27PM PinDMD.DLL 1/20/16 8:40AM PinDMD.Ini ========== [communication] debug=0 comport=COM3 [pinmame] log_frames=0 DMDExt 1.71 installed in my VPinMame directory (C:\Pinball\Visual Pinball\VpinMame), I also make sure it is my Path so there is only a single copy of it installed. Primarily this is done for PinUp-Player. DmdDevice.Dll 7/13/18 9:16PM DMDExt.Exe 7/13/18 9:14PM DmdExt.Ini ---------- [global] ; how to downscale SEGA 192x64 pixel games to smaller displays: fit, fill or stretch resize = fit ; flips the image horizontally fliphorizontally = false ; flips the image vertically flipvertically = false ; enable or disable frame-by-frame colorization (inactive in VPX bundle) colorize = true ; a DMD that renders with nice dots on a computer monitor [virtualdmd] enabled = false ; virtual dmd stays on top of all other windows stayontop = false ; hide the resize grip hidegrip = false ; ignore the aspect ratio of the rendered dots when resizing ignorear = false ; use VPM's registry values when positioning the virtual dmd useregistry = false ; x-axis of the window position left = 0 ; y-axis of the window position top = 0 ; width of the dmd in monitor pixels width = 1024 ; height of the dmd in monitor pixels height = 256 ; scale the dot size (set to 0.8 for same size as pre-1.6.0) dotsize = 1.0 [pindmd1] ; if false, doesn't bother looking for a pinDMD1 enabled = false [pindmd2] ; if false, doesn't bother looking for a pinDMD2 enabled = false [pindmd3] ; if false, doesn't bother looking for a pinDMD3 enabled = true ; COM port, e.g. COM3 port = COM3 [pin2dmd] ; if false, doesn't bother looking for a PIN2DMD enabled = false [browserstream] ; if enabled, stream to your browser in your LAN enabled = false port = 9090 [vpdbstream] ; if enabled, stream DMD to https://test.vpdb.io/live enabled = false endpoint = https://api-test.vpdb.io/ [video] ; if enabled, writes frames to an .avi file enabled = false ; path to folder or .avi file. if folder, gamename.avi is used. path = [pinup] ; if enabled, send frames to PinUP. enabled = true
Pablo Smiraglia Posted July 4, 2018 Posted July 4, 2018 2 hours ago, GAH1068 said: @Pablo Smiraglia - see below. I just took this from my system a few moments ago. I have the generic pinballX video running on my PinDMDV3 when I am in Pinballx. I have never got around to doing dmd videos for the games, it is pretty low priority for me. I have no issues either running dmdext.exe (FX3, PBA, Timeshock, Pinball Wicked) or using the built-in DMDDevice.Dll for VP9 and VPX tables. In PinballX Game manager make sure to check Disable DMD for the games otherwise your will get the issue you are reporting. Up until a few versions ago that check mark really didn't appear to do anything. Now, unless I check it in game manager the PinballX default DMD would be displayed and then the in-game one would not work. This might be your problem. Thank you for this. I need to ask though, do you use *any* videos or images in Pinballx ? I realize your DMD is working on VP, FX3, etc. (so does mine). My problem is with images and video when in the front end. from the files you list, you are using pindmd and not dmddevice when in pinballx.
GAH1068 Posted July 5, 2018 Posted July 5, 2018 I just have the default pinballx video playing on my pindmd3. I'll try and enable a video file next time I boot up
jhouff Posted July 15, 2018 Posted July 15, 2018 So I have an odd issue that just came about that is similar but also different with the recent PinballX release. Using PinDMDv3 I have real DMD previews but when I launch Pinball Arcade dmdext crashes so DMD doesn’t work in game. If I boot Pinball Arcade outside of PinballX with dmdext works like a charm. Seems to be an issue specifically with PinballX and DMD previews.Sent from my iPhone using Tapatalk
Goggles Posted July 22, 2018 Posted July 22, 2018 Same issue as above. Shows default Pinballx video on dmd, and continues to run after I launch a table. No issues running tables with DMD outside of PinballX. Also, DMD for Pinball FX3 works on 95% of the tables. I have no idea what's up with that either.
emalave Posted July 22, 2018 Posted July 22, 2018 same issue as Goggles. If I rename pindmd.dll then the table dmd works. if I dont, I returns a pindmdv3 not found error or thew pinballx videos stays playing. Terrible., Been trying to fix this for 6 weeks.
jhouff Posted July 22, 2018 Posted July 22, 2018 Ok. I think GAH1068 fixed it for me What is GAH1068?Sent from my iPhone using Tapatalk
BrandonLaw Posted July 22, 2018 Posted July 22, 2018 4 minutes ago, jhouff said: What is GAH1068? Sent from my iPhone using Tapatalk A member...
jhouff Posted July 22, 2018 Posted July 22, 2018 A member...Got it haha! Yeah I see it now. Unfortunately following his above instructions didn’t solve my issue. For me I had to disable DMD previews (by renaming the .dll) for Pinball Arcade to start working again. Such a bummer but oh well.Sent from my iPhone using Tapatalk
emalave Posted July 25, 2018 Posted July 25, 2018 Solved. Damn Game manger for Pinball X stinks. You have to check HIDE DMD for EACH TABLE for the DMD to show. Makes no damn sense. If you want the PINBALL X dmd to stay for tables that dont have a dmd, leave it Unchecked. Terrible support and design of the game manager.
Draco1962 Posted July 25, 2018 Posted July 25, 2018 1 hour ago, emalave said: Solved. Damn Game manger for Pinball X stinks. You have to check HIDE DMD for EACH TABLE for the DMD to show. Makes no damn sense. If you want the PINBALL X dmd to stay for tables that dont have a dmd, leave it Unchecked. Terrible support and design of the game manager. It may not make sense to the uninitiated but after using it for a while it does make sense. In other words, you are telling PinballX NOT to display a default or game named DMD file and allow for the program (PinMAME, etc.) to load the DMD instead (hence the NO selection required in Game Manager). While I agree that Game Manager isn't going to be all things to all people, it isn't that bad. I admittedly prefer to load my XML files into Notepad++ for editing/adding/deleting tables. As for you comment about terrible support, I will strongly disagree with you. Support here is mostly member driven with the experienced members helping those that are new to fold. The author takes supporting his product seriously but can't be on call 24/7 for what he created to support a hobby - not a source of income. 1 1
