Anyone knows howto set custom brightness of the adressable leds matrix when browsing tables?
thnx
Wow, not sure?  If you are driving them with pulse wave modulation it will take some circuitry using a MOSFET. Not sure how you would interface the hardware/software?
yeah theres a way to do it, you mean your back mx animations?
Use <FadingCurveName>Linear0To16</FadingCurveName> in your cabinet.xml file, and change the 16 to whatever level of brightness you want. 16 is the lowest setting.
