I just replaced the command line steam ID and it launches the product. However, it seems there is no command line support to go directly to a table. So you end up in the main menu.... But worse than that is, that you cannot enter your initials without a keyboard attached.... not to mention missing local high-scores.
I hope they will listen to the community and add these things so it becomes as good as pinball fx2...
Did you try the settings as noted here?
For the entry in the Pinballx.ini for Pinball FX3 section is likely [PinballFX3].
Hello
Ok for me, all table of pinball fx3 run ok
I have creat new table Jaws and ET
But back to the futur... I have tried "Back-to-the-Futur" it's bad
I dont no how write this table ! Could you tell me please....
  • Draco1962 changed the title to [RESOLVED] Pinball FX3, how to add?
  • Draco1962 locked this topic
