Hello!  When I tried to load Gameex today, I got the below error message.  I ran Gameex yesterday with no problems and today it wont load.  Any help would be appreciated.  I tried uninstalling and re-installing and that didn't help.
Jim
14:43:39.3  2/14/2017:  Opening Configuration File
14:43:39.3  2/14/2017:  GameEx: Version 14.70: Starting Log
14:43:39.3  2/14/2017:  Windows 10 Home 32-bit
14:43:39.3  2/14/2017:  Aero running
14:43:39.3  2/14/2017:  Initializing Vista/Windows 7 volume control
14:43:39.3  2/14/2017:  Getting CPU and RAM info
14:43:39.3  2/14/2017:  Intel(R) Core(TM) i5-3550 CPU @ 3.30GHz, 3278MB
14:43:39.3  2/14/2017:  3.31Ghz - 4 Cores or CPU's
14:43:39.3  2/14/2017:  Running Randomize()
14:43:39.3  2/14/2017:  Loading PlugIns
14:43:39.4  2/14/2017:  Checking for applications to Launch On Startup
14:43:39.4  2/14/2017:  Setting default net connection limit to 15
14:43:39.4  2/14/2017:  Running Misc startup tasks
14:43:39.4  2/14/2017:  Setting Menu types
14:43:39.4  2/14/2017:  Getting Configuration Values
14:43:39.4  2/14/2017:  --**--
14:43:39.4  2/14/2017:  Error: Object reference not set to an instance of an object.
14:43:39.4  2/14/2017:     at GameEx.GameEx.MainForm.a(Boolean A_0, String A_1, Boolean A_2)
14:43:39.4  2/14/2017:     at GameEx.GameEx.MainForm..ctor()
14:43:39.4  2/14/2017:  Disposing Plugins
14:43:39.4  2/14/2017:  GameEx is exiting with errors
14:43:39.4  2/14/2017:  Deleting search cache
14:43:39.4  2/14/2017:  ERRORS DETECTED: EXITING
14:43:39.5  2/14/2017:  Bye
I think I finally figured it out.  I went into the setup program and changed the theme back to default and everything seems to be working.
Sorry,
Jim
I read others commenting that you may have to change around with the themes on occasion to get one that plays nice with your setup.  Hopefully that's all it was!
