I may have missed this, but I didn't see the Trackball support yes/no in the setup wizard. I usually use my trackball to scroll up and down through games in the original GameEx, but it keep activating my mouse pointer in Evolution.
Can you edit more detail in the .ini then you can in the setup wizard?
Evolution is, "as is" at the moment, it doesn't have the same support that GameEx has, being that it is unreleased. If you have a "clue" you can get it working quite well, but you must know that you will have to already know how to run things to get the most out of it. ;)
Thanks. I'll keep trying to get a clue. Haha. I like the looks of it so far.
I thought I did.. I had this exact setting changed for GameEx but I just spaced...
