On 3/12/2010 at 3:48 PM, Tempest said:
Run the setup wizard.
Click 'Next'
Select'Custom'
Click 'Next'
Scroll down, and put a tick in the box 'Emulator Selection'
Click 'Next'
On the left, highlight the next empty slot that you have available
On the right, highlight '[Console] Nintendo SNES ZSNES'
Click on the 'Left Arrow' button to import the config.
I don't have the latest version on this computer, but it should ask you if you want to download the emulator, and setup the paths for you.
I downloaded emulators from a website how do I put them into GameEx? Is there a folder in the C drive i can drop them into? I don't want to have to use the emulators that GameEx makes me use.
Hi imek, welcome to the GameEx forums.
GameEx doesn't care where you put the emu's you decide to run.  Place them in a directory structure you're comfortable with, and point GameEx to them in the Setup Wizard,
