For some reason when I updated my gameex application recently, suddenly all my name icons are out if whack when I scroll through the menus.
Looking at the icons in Windows, they look correct, so somehow gameex looks like it is mangling them somehow.
Hi laggerific,
Could you please provide a copy of your gameex.ini file as well as a recent log.txt file? See my signature if you are not sure how to do that.
Also, if you could provide a screen shot of what you are referring to, it may also be helpful. Note that GameEx will have to be windowed for you to capture the image.
I finally got a chance to look into this further, and it seems to be a problem with something that Gameex is caching, as I removed the icons completely, and they still showed up in the gameex UI.  Where would something like that be cached?
I managed to fix the issue by rescanning the roms.  Everything is right as rain with the icons again.  Just wanted to close the loop...thanks all.
