Is it or it may be possible to iniciciar PinballX display a menu systems?
HyperSpin can be configured as multisystem and in that case, at the beginning shows a selection menu systems.
PinballX shows all tables start and then we can select a particular game if the default filters are disabled.
It would be nice menu with its wheel and custom artworks HyperSpin type.
¿Es o puede ser posible que al iniciciar PinballX muestre un menú de sistemas?
HyperSpin puede configurarse como multisistema y en ese caso, al inicio muestra un menú de selección de sistemas.
PinballX muestra todas las mesas de inicio y luego podemos seleccionar un juego concreto si los filtros por defecto están deshabilitados.
Estaría bien un menú con su wheel y artworks personalizados tipo HyperSpin.
This would be a Feature Request but I think the goal is to keep PinballX flatter with less menus, than a conventional FE such as GameEx or Hyperspin.
My idea is to put as an option , to choose in the configuration the traditional method or menu systems method.
Understood. I provided the link in my response for this kind of request.  B)
You will want to describe it there, not here, if it will have a chance for consideration.  Thanks!
