Had a finished setup working with 50+ emulators for years. Turned on the machine a couple weeks back and now it only lists 8. Isn't gameex.ini the place that determines lists and setups of emulators? When I view the file it lists tons of emulators. Is there another location that may be overriding that file so only 8 emulators are listed?
You could do a Windows search for that file and see if it turns up more than one. Did your install path inadvertently change?
