Hi guys,
When from GameEx I run Fusion everything is working except the dpad of my second xbox controller.
Basically both the dpad of controller 1 and controller 2 have the same keys in Sega Master System, so when I play games like street fighters in 2 players mode it's unplayable.
How can I configure it?
In fusion.ini I have realised that 200, 208, 203, 205 is the configuration of the dpad for player 1
Which ones are the codes for player 2? I cannot find them anywhere. Also what lines do I have to modify to make it work?
Many thanks!
; Fusion Configuration File
; Graphics Compatibility Options
ForceCompatibleGFX=0
CompatibleGFXOpt=0
EnhancedGFXOpt=0
ForceFullScreen32=0
VistaAeroIgnore=0
VistaNoWndVSync=1
DebugFlags=0,0,2,2
; Sound Compatibility Options
ForceSWBuffer=1
; SG1000/SC3000/SMS/GG Specific
LastSMSROM=D:\Arcade\System roms\Sega Master System\roms\Street Fighter II (Brazil).zip
LastGGROM=D:\Arcade\Emulators\Fusion\
SMSUSABIOS=
SMSJAPBIOS=
SMSEURBIOS=
GGBIOS=
SF7000IPL=
SxMFiles=D:\Arcade\Emulators\Fusion
SMSStateFiles=D:\Arcade\Emulators\Fusion
SMSPatchFiles=D:\Arcade\Emulators\Fusion
GGPatchFiles=D:\Arcade\Emulators\Fusion
SMSSpriteLimitDisable=0
YM2413Disable=0
SMSBIOSDisable=0
SMSBorderDisable=0
GameGearZoom=0
GameGearFull=0
; MegaDrive/Genesis Specific
LastGenesisROM=D:\Arcade\Emulators\Fusion\
SRMFiles=D:\Arcade\Emulators\Fusion
GenesisBIOS=
AutoChecksums=0
GenBorderDisable=0
; Mega CD/Sega CD Specific
LastSegaCDImage=D:\Arcade\Emulators\Fusion\
SCDUSABIOS=C:\SegaCDBIOS\us_scd1_9210.bin
SCDJAPBIOS=C:\SegaCDBIOS\jp_mcd1_9111.bin
SCDEURBIOS=C:\SegaCDBIOS\eu_mcd1_9210.bin
SCDStateFiles=D:\Arcade\Emulators\Fusion
DefaultDrive=X:X:X None
CDReadAhead=4
CD+GMode=0
ForceASPI=0
BRMFiles=D:\Arcade\Emulators\Fusion
BRMPerGame=1
LEDEnabled=1
PerfectSync=0
; 32X Specific
32XM68KBIOS=c:\32XBios\32X_G_BIOS.bin
32XMSH2BIOS=c:\32XBios\32X_M_BIOS.bin
32XSSH2BIOS=c:\32XBios\32X_S_BIOS.bin
Disable32X=0
Fast32XTiming=0
; Expert Options [DANGER! RTFM!]
RefreshRate60Hz=60
RefreshRate50Hz=100
UseExpertModes=0
UseAutoSwitching=0
MinSwitchDelay=100
Mode256x240=640,480,60,100,640,480
Mode256x480=640,480,60,100,640,480
Mode320x240=640,480,60,100,640,480
Mode320x480=640,480,60,100,640,480
; File History
FileHistory0=D:\Arcade\System roms\Sega Master System\roms\Street Fighter II (Brazil).zip
FileHistory1=
FileHistory2=
FileHistory3=
FileHistory4=
FileHistory5=
FileHistory6=
FileHistory7=
FileHistory8=
FileHistory9=
FileHistoryA=
FileHistoryB=
FileHistoryC=
FileHistoryD=
FileHistoryE=
FileHistoryF=
ShortenHistoryNames=0
; Netplay Settings
NetplayName=
NetplayServer=
NetplayPlayers=2
NetplayLatency=6
NetplayBandwidth=1
; General Settings
WAVFilesPath=D:\Arcade\Emulators\Fusion\*.wav
VGMFilesPath=D:\Arcade\Emulators\Fusion\*.vgm
AVIFilesPath=D:\Arcade\Emulators\Fusion\*.avi
ScreenshotPath=D:\Arcade\Emulators\Fusion
ScreenshotType=0
ScreenshotMode=1
CurrentCountry=0
CountryAutoDetect=1
CountryOrder=0
CurrentWaveFormat=2
SoundOverdrive=0
PSGNoiseBoost=0
SoundSuperHQ=1
SoundDisabled=0
SoundFilter=0
CurrentRenderMode=1
FullScreen=0
DWindowXPos=253,0,0,0
DWindowYPos=133,0,0,0
DWindowSize=224,1,128,2
DResolution=224,1,128,2
DRenderMode=0
DFixedAspect=1
DFixedZoom=0
DFiltered=1
DNTSCAspect=1
DNearestMultiple=0
DScanlines=4
VSyncEnabled=0
Player1Keys=200,208,203,205,42,29,57,2,56,44,45,46,0,0,0,0
Player1bKeys=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Player1cKeys=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Player1dKeys=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Player2Keys=205,208,203,205,17,18,30,3,31,16,26,27,0,0,0,0
Player2bKeys=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Player2cKeys=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Player2dKeys=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Player1Buttons=32,33,34,35,0,1,2,3,4,5,6,7,8,9,10,11
Player1bButtons=32,33,34,35,0,1,2,3,4,5,6,7,8,9,10,11
Player1cButtons=32,33,34,35,0,1,2,3,4,5,6,7,8,9,10,11
Player1dButtons=32,33,34,35,0,1,2,3,4,5,6,7,8,9,10,11
Player2Buttons=32,33,34,35,0,1,2,3,4,5,6,7,8,9,10,11
Player2bButtons=32,33,34,35,0,1,2,3,4,5,6,7,8,9,10,11
Player2cButtons=32,33,34,35,0,1,2,3,4,5,6,7,8,9,10,11
Player2dButtons=32,33,34,35,0,1,2,3,4,5,6,7,8,9,10,11
Joystick1Type=1
Joystick1bType=1
Joystick1cType=1
Joystick1dType=1
Joystick2Type=1
Joystick2bType=1
Joystick2cType=1
Joystick2dType=1
Joystick1Using=0
Joystick1bUsing=0
Joystick1cUsing=0
Joystick1dUsing=0
Joystick2Using=0
Joystick2bUsing=0
Joystick2cUsing=0
Joystick2dUsing=0
Player1MSKeys=200,208,203,205,42,29,2,0
Player2MSKeys=200,208,203,205,17,18,3,0
Player1MSButtons=32,33,34,35,0,1,3,0
Player2MSButtons=32,33,34,35,0,1,3,0
Joystick1MSType=1
Joystick2MSType=1
Joystick1MSUsing=0
Joystick2MSUsing=0
MultiTapType=0
InvertMouse=0
LightgunCursor=0
FPSEnabled=1
CurrentRenderPlugin=0
AllowSleeping=0
AlternateTiming=0
DisableShortcuts=0
ThreadPriority=0
StaticDisabled=0
Brighten=0
CartBootEnabled=0
VGM_Version=16,1
MSNStatusEnabled=0
Why wouldn't you just configure the controls through the Fusion UI?
Sent from my SM-G930R4 using Tapatalk
Hi Adultery, please let me know what you mean.
I tried by the fusion interface but it is not detected correctly (both dpad have been assigned to the same codes 200,208,203,205) so I wanted to modify the .ini.
Do i have other options to configure my 70 emulators to my 2 Xbox controllers skipping their native interface or config/ini files? :) Last time I configured a cab was 10 years ago so I might be a bit outdated with the news.
Any idea how to retrieve all the codes for both controllers? (200, 208,203,205 is for a player1 dpad, I need the player2 dpad and no idea about what values I need to move the player2)
Many thanks!
Hi Draco,
Thanks for your reply.
I configured the controllers in the same way. They are both detected but it's only the dpad of controller2(up,down,left,right) that is stuck to the same keys assigned to the dpad of controller 1. The buttons (punch, kick/jump) of controller 1 and 2 are fine.
-What I need to know are the values of the controller 2 dpad ( and what part of the .ini I should modify). How can I retrieve the numbers? Dpad1 is 200,208,203,205. Dpad2 no idea 'cause it is not detected.
-If someone that uses 2xbox controllers can share the .ini that would be great too
Many thanks
Hey Thinker,
So I broke out both of my XBoxOne controllers to see if I could help you out. Funny enough though, I configured both through the Fusion GUI and had no problem with the setup. I tried both using the left stick and then the dpad for movement and they worked independantly just fine (in Streets of Rage at least).   :)
Anyway, I am not super familiar with the fusion.ini, so I attached it for you. This has both controllers configured exactly the same with the dpad for movement. I hope it helps.
Fusion.iniFetching info...
Hi RedDog,
Thank you very much for the config.
Unluckily does not work because player 2 dpad is recognised in the same way as player 1 dpad, so no idea how to tell fusion to recognise it differently. If I put the right values of a standard xbox 2 controller it does not work because in fusion it has the same values when recognised as dpad for controller 1.
It's very annoying, I had to use the axis in controller 2 (and they are not very accurate) and anyway if player 2 touch the dpad, player 1 will move because it is set with dpad1.
Ok this is weird, controllers works (as mentioned above) in fusion but not at all when fusion is launched through gameex. I have no problems with other emulators.
How can I fix it? :/
I have attached fusion.ini
And the screenshot of the configuration
The thing is that it sounds like it's something with your setup. I used fusion for a really long time, and I used Xbox controllers. Never had that problem.
Hey Thinker. I went back and tested Fusion through GameEx with my two XBoxOne controllers and I was able to use the dpads on both just fine. Do keep in mind that my tests are not exactly the same as your since you are using XBox360 pads.
Hopefully there isn't some wierd conflict between GameEx, Fusion or your gamepad drivers.
It would be best if you could post your gameex.ini file instead of doing a screenshot of the Fusion config. There is a lont more under the hood than just that.   :)
Finally, after I wasted 2 days I fixed it. Now dpads work :)
To configure the dpad for xbox controller 1 and xbox controller 2, you have to set fusion in windows mode (NOT FULL SCREEN) and only FROM Gameex you have to configure it! Not from fusion itself.
You do not need to touch the .ini but  I have added it anyway in case someone needs it.
This is the configuration
Port 1: 3 Btn Pad:   -4. Controller (Xbox 360)
Port 2: 3 Btn Pad:   -3. Controller (Xbox360)
Port 1: Control Pad: -4. Controller (Xbox 360)
Port 2: Control Pad: -3. Controller (Xbox 360)
After that exit from Gameex, and add in Setup Wizard full screen mode:
Fusion.exe -sc -zip -sf7 -7z -mv -sms -sg -sf7 -auto "[ROMPATH]\[ROMFILE]" -fullscreen
Fusion.ini
