[RESOLVED] Help! reinstalled Gameex, now getting an error.
I had to reinstall my Gameex... i saved and copied my setup, but now when i copied it over, it doesn't run and i'm getting errors... I don't know what the problem is but it's probably something stupid i overlooked... Attached are my ini and log files.
GameEx.ini
Looks like your emulator paths are wrong. It's weird that your drive letters are all lowercase. Maybe I'm just old as dirt and that doesn't matter? If not, then check and make sure your F: drive still exists.
Wrong == not right.
You say everything is in D: drive? There's F: and G: references in your ini. You don't have F: and G: drives? Mystery solved. ;)
Illegal path means it's not a valid path, which happens if you specify a path on a drive that doesn't actually exist. Ya dig? :)
At the end of GameEx setup wizard, did you let it verify?
As Adultery has already mentioned, this is almost always a path issue.  The verify step will help you see if that's it or not in short order, and give you insight as to what it is if that isn't it.
