Hi Tom and others.
As the title says, after updating to 2.13 PinballX no longer closes the running DMD/PinDMD2 upon exiting the frontend.
I didn't change anything in the settings.
Please advise when you can.
Junky
I temporarily fixed this by running PinDMD-CLR.exe upon the exit of pinballx.  This works, however it was not needed before this latest 2.13 update.
Junky
I won't be able to try until saturday Tom. Thanks.
From what I saw the other day, 2.13 was correctly loading and exiting tables and b2s backglasses as well as all of the media files within the front end.
Thank you.
Junky
Guys, i loaded the new extracted files and the dmd still shows the last thing it displayed while pinballx exited.  I can see my desktop on my backglass and playfield but my pin2dmd is showing a still frame from the vid.
Tom.
Replacing the 2 xdmd dll's that you posted did not fix the problem.  In fact these 2 dll's cause pinballx to crash each time I try to exit the frontend (and the dmd and led's stay on).
Any thing else to try?
Junky
  • 5 weeks later...
3 hours ago, xagesz said:
Dead thread I know. I am running a Pindmd1 and have the same issue
Please provide copies of your pinballx.ini and log.txt files for review. Click on the PinballX How to ask for help link in my signature for instructions on how to locate and submit the files for us to review. Thanks.
