Hi Guys,
Need a bit of advise/ help im running pinball x obviously on my home made virtual pin cab with 3 screens a 46"( hdmi )  for the play field , a 26" for the back glass and a 7" monitor ( which only has VGA ) for the DMD the problem i have is how do i hook up the gfx to work all 3 monitors i can only get 2 in any order to work. the gfx are built in AMD Radeon HD 8000/7000 with VGA, HDMI and DVI-D what connectors adaptors do i need in order for all 3 screens to function, i got a DVI to vga adapter but no go,ive tried the net but got a bit flummoxed and i know you guys will just tell me what i need :-)
As usuall Much appreciated in advance.Ian.
Edited by simbamame
RESOLVED
Hi Ian - Can you tell us more about your kit?  Probably would help to know about the motherboard brand and model you are using as well as the OS. Having a copy of your log.txt and pinballx.ini files may also be of help.
