Hello everyone , I have a little problem when I run GameEx in the games tab emulate all my consoles are but when I want to start a game Sega CD , it starts after the start and I 'm on the interface or c " is ecris NO- CD !! whereas when I run everything by melting nickel works !! thank you for helping me
Hi Shoguy,
Welcome to the forums!
Please do us a favor and post your GameEx.ini and a log.txt file after you attempted to run a Sega CD game.
Check my signature below for how to find those files.
Actually shoguy, I will make it super easy for you for this one.
  • Try to run a Sega CD game and then exit GameEx
  • Grab the log.txt file from the GameEx\LOG folder.
  • Grab the GameEx.ini file from the GameEx\CONFIG folder
  • Post both files in your reply
The next time you need to post for help, please look over the How to ask for help guide.
Thanks!!!  :)
welcome back Reddog thank you for taking time for myself and not have to desoler post my request in the rules !! here I have followed your instructions and I buddy you the 2 files again thank you in advance
GameEx.ini
Shoguy,
From my testing, I was unable to get Fusion to detect an image mounted to a virtual drive. Fusion does support image loading itself. I suggest you try using this command instead:
Fusion.exe -scd -fullscreen "[ROMPATH]\[ROMFILE]"
thank you very much Reddog it works !!
a big thank you for your help, though I walk and read on forums but I'm learning little by little ..not too stalling computer !!
Good day to you
