When switching between Video snaps sometimes there is a beep sound (loud), how do I remove this.  The video snaps sound are fine, I have checked these outside of GameEx.
Seems to be a pretty unique problem you have, have you checked your log for clues?
As a suggestion, I would change some of the audio settings.
In the setup wizard go to Audio Settings and disable jukebox mode as a test.  If that doesn't get it, try disabling GameEx Sound FX.
