<_< Hello ,
i've downloaded the mame rom fullset 0.170 , so i decided to update Mame to 0.170 in Gameex , everything went good BUT no Neogeo games are shown....
Could someone point me in the good direction , should i modify something ?
If you need my ini and log just tell .
Thanks in advance !
As a general rule, it is always a good idea to post those when you are having issues.
I would guess that an old bios is to blame
that and having verify roms set to yes, would prevent them from showing after doing a game list update.
Check this section under Advance MAME settings, and if needed change to NO, relaunch gameex, and update
:) Thank you so much , that was the thing to do !!
Thanks again , i really apreciated your help !
