if i run outside of pinballx its ok but if i run with pinballx it wont run table it stays on start screen and flashes once then back to start screen im using PPU_Starter.exe
40 minutes ago, Carny_Priest said:
Now that Pro Pinball added cab support, I don't think you even need PPU_Starter anymore. Do you have Steam or a non-DLC version?
Say what? Do you have a working command line for launching as a separate program under PinballX?
I still use a form of PPU_Starter although almost all of the instructions are commented out. I still run a xpadder sort of program because I have not configured my controller for the game yet.
Otherwise, this should work just fine:
And, yes, there is a parameter for launching straight to the simulation, bypassing the menu.
The command in my case is:
"C:\Program Files\Pro Pinball Ultra\ProPinball.exe" m3 q
but I still need to set up PinballX to run it.
Working now, it took me a while to remember that you have to set something up in game manager as well (I've been away from PinballX for at least a year).
And you got it working without a PPU and got it working how?
I set up the command from a couple of posts back in the Other Systems section and then set up 1 table in the game manager. I can't give specifics as I'm not near the machine at the moment. I'm not using the Steam version but that also seems to work fine for people.
