I have configured Chankast (Dreamcast emulator) in GameEx. Unfortunately everytime I select a game to start playing the screen goes black. I hear the game functioning in the background but do not get a picture. It was functioning correctly a few updates ago but now I can't figure out what went wrong. Anyone have any ideas?
does it work ok running without gameex??
Yeah, it works perfectly. The problem only happens when I try running Chankast through GameEx.
Sounds like its not running fullscreen, so Gameex isnt showing it. Im not sure what the shortcut for fullscreen is on Chankast, but most likely it's Alt-Enter. When you hear the game playing, but don't see it, try tapping alt-enter an seeing if it shows up. if it does, then you just need to find an option or switch that will cause itt o start in full screen mode.
Are you using chankast_launch.exe with a shortcut to run it? Do you have the ShowDesktop setting in GameEx set?
That's taken care of the problem! ShowDesktop worked! Thanks for everyones help. How about exiting from Chankast from GameEx with a SlikStik Classics?
