Hi guys
Think I screwed up config on Instant Sheller and now it is stuck.
Basically Windows is not shelled, the programme only boots back to the undo button though.
When I try to undo it gives me the below error. I think that some parts of the shell worked and some didn't so now it thinks it needs to reverse changes. Basically i just want to be able to run it again fresh, can anyone help at all?
************* Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at c.h(Object A_0, EventArgs A_1)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Tom
  • 4 months later...
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
Spoiler
************** Exception Text **************
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
InstantSheller
    Assembly Version: 1.0.4700.35893
    Win32 Version: 1.0.4700.35893
    CodeBase: file:///C:/Users/Josh/Downloads/instantsheller/InstantSheller.exe
    Win32 Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 2.0.50727.5495 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.5483 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Have you tried to run it again via the below method?
CTRL, ALT and DEL to get the task manager, choose "file", "run new task" and type explorer.exe
Once in file explorer you'll have access to what you need to get to use the undo feature.
Thank you tthurman...It seems the issue is that it only undid specific parts of it...
I am on my desktop perfectly fine and using it, however the boot up screen etc is still missing...it loads to desktop with full functionality, but when going into instant sheller from desktop it still says "undo" and no matter how many times i try to, it gives that error and still have not fully undone itself.
I could easily be incorrect here, but if your jukebox program is also 32 bit, as in the case of what Tom is commenting on, it stands to reason the same may apply. This being the case you need to run the 64 bit version of explorer per his post, which may in correctly "undo" things.
Note that this is completely out of my area of expertise, but it would seem at least plausible that the same situation exists in this case, just with the jukebox software as opposed to GameEx.
Regardless, it's the only suggestion that comes to mind at this point.
Thank you sir I will look into that tonight as I am not sure off hand what the jukebox software is running. I did look last night though and my explorer.exe was running as x64
I was able to check the software and it is running @ 32bit while my OS is @ x64. Do you think I am having the same issue as the post that was referred just backwards?
