Hi
I downloaded the convert-it software suite and activated it with the license key from the my purchases page and it will work for the one time you activate it then next time i start it it wants me to activate it again, It worked for a few days without this happening but now it is every time i start it. Also the input fields to select files and formats are blank and just a thin line.
I have tried uninstalling and re installing but it is still doing the same thing any ideas?
Cheers
Problem was i loaded a whole bunch of fonts and must have screwed up the font that convert-it uses. Activation seems fine now also.
Cheers
