I have daphne setup and working with snaps, videos. and also setup singe as a different emulator. is there anyway to merge the 2 and have sing be in the same list as daphne? I didn't see any themes that had singe layouts and I don't have the time to create my own but it may be something I will have to do
thanks
Unfrotunately there is no way to create an Emulator Group with integrated DAPHNE support setup and another program setup as a separate emulator. You would have to setup up both as separate emulators and then include them as part of an emulator group to combine the entries in the same menu.
As for creating theme elements, you could copy the ones for DAPHNE perhaps and rename replace the Daphne text for Singe in the file name within the theme\media path you are using and assign this under the Custom Background settings via Advanced Emulator Setup for Singe.
went into the theme is was using and used the template in it , named it to singe . put the mane singe-daphne on the top of the template so it looks good enough for me . don't really mind them being apart ( daphne and singe) just as long as it had its own template.
thanks again
