Hi! Does anyone know of a way to reduce the input lag from xpadder? I experience around a 1/2 second delay on my flippers when playing Pinball Fx2. Are there alternatives other than XPadder that reduce lag? Thanks!!
Hi Black Mage,
There isn't but you really shouldn't be experiencing any human perceptive lag using Xpadder. Been using it for years and if any lag is present, my brain certainly cannot pick it up.
Also, under what circumstances are you using Xpadder with PBFX2? It works natively with most devices without the need for any 3rd party intervention.
Specifics are needed here to get any meaningful advice i think.
I'm not saying you aren't experiencing what you say, but a little about your setup, how and why you are using Xpadder etc will help identify why you are experiencing problems :)
You may want to read this thread. Likely it is Pinball FX2 settings that need to be tweaked and/or your GPU rendering. I would start with the profile settings for Pinball FX2 since they are limited to the program rather than tweaking the GPU globally. I had a similar issue and the profile changes worked for me.
