hi it seems that after one of the recent updates or maybe im just noticing this with attract mode only using mame instead of all of my other emulators that when the screensaver in attract mode plays a mame game preview or video that most of them just stick on the navy blue info screen that you type ok or select to bypass in the actual game. this is also true that i can hit ok int the attract mode and the preview will start, any ideas? thanks for the help.
GameEx.ini
Nothing jumps out at me in your ini or log.
What codec pack are you running. If you're not, and have been using what comes with win 7, then I would suggest you grab the LAV filters from the PinballX site.
Recent upgrades are moving to the LAV filters for both GameEx, and PBX (these LAV filters are included in the sharks BTW, so don't panic thinking you need to uninstall those, if you do have them installed)
