Can someone please tell me how to rotate Future Pinball for a cocktail cabinet.Thanks in advance
You might get a better response posting in the PinballX forum, even if you are using GameEx to run Future Pinball. Them guys know their stuff! Either way i'm sure between the two forums someone can help you out :)
You may want to jump to this thread post first, which also has links to some PinballX solutions. I recommend confirming whether or not your GPU supports rotation.
Alls fine my Dell U2715H-3 Does support rotation. Thanks
Does this mean you were able to get a solution to work? If so, what did you do to get this resolved so that the next person that has a similar problem can use your experience as a point of reference?
There is a rotation setting of 0,90,180 and 270 deg in the display options within the editor, or you can use the arcade render option also.
Thanks RR! We know that you know your way around this stuff or can find it easier than most.
My goal is to try to get the user of the OP to share his solution. Never hurts to give a little back to the community when you get something to work and others put effort to get you there! Just a quick "Alls fine..." or, "Thanks, it's working..." and nothing else doesn't help the next n00b much. B)
Yes I found it within the Pinball editor as rockyrock said! plays a lot better long ways, you can see all the table and head board! just peachy :D
