I recently reinstalled gameex after a hard drive crash. I reinserted the registry. Then I put gameex into startup so that it would immediatly startup but for some reason it crashes. It will run if I just click on the gameex icon but not in startup. Some one please help. I also turned up alot of services any service needed to run in startup?
As far as basic troubleshooting, go backwards. Take out GAMEEX. Make sure you have it all the way out (directory c: too). Then, try to eliminate everything possible on your startup. Reload GAMEEX WITHOUT the reg hack. If it works, then put the hack in. Let us know what happens.
seems to be working now i reinstalled it in a different directory and I also took out an old version of .net framework now i have version 1.1 ans 2.0 installed.
