DietCoke Posted February 22, 2015 Share Posted February 22, 2015 I'd like to get a screenshot but have not had luck getting it. Anyhow, the menu in my theme is laid out properly it seems, but there are underlines between each list item, and they stretch all the way to the right side. Anyone know how to get rid of them? I'm bastardizing the Ambient Occlusion theme.Edit: Here it is: Link to comment Share on other sites More sharing options...
RedDog Posted February 22, 2015 Share Posted February 22, 2015 I was curious how the underlining was done, so I took a look.There is a file in the GameEx\THEMES\Ambient Occlusion\MEDIA folder named Unselected.png. The theme displays this file for each selectable line that is not currently selected. The result is that the menu selections all look like they are underlined.You can clear the lines in the theme by opening the file in a graphics editor like photoshop or gimp and clear the graphics (be sure to retain the transparency). 1 Link to comment Share on other sites More sharing options...
hansolo77 Posted February 22, 2015 Share Posted February 22, 2015 Good Call. I was going to suggest the problem is related to the theme as well. More than likely, the theme was designed in a different resolution than what you're using, that's why you see graphics not properly aligned, etc. You can try doing as RedDog suggested, and make changes to the theme itself. Or, for a test, try simply changing the theme and see if it goes away. That way you don't waste all your time trying to fix it, if in fact that ISN'T the problem. Link to comment Share on other sites More sharing options...
RedDog Posted February 22, 2015 Share Posted February 22, 2015 I tested the fix before I made the post. Link to comment Share on other sites More sharing options...
Draco1962 Posted February 23, 2015 Share Posted February 23, 2015 Here is the Unselected.png file I use in most of my themes. Extract it to replace the same file in your theme in the \MEDIA folder.Unselected.zip Link to comment Share on other sites More sharing options...
RedDog Posted February 23, 2015 Share Posted February 23, 2015 Psssst, Draco...I think you forgot the file...EDIT: There it is... 1 Link to comment Share on other sites More sharing options...
Draco1962 Posted February 23, 2015 Share Posted February 23, 2015 Actually it was 100% transparent so it did not appear, hence the replacement within a .zip file. 2 Link to comment Share on other sites More sharing options...
RedDog Posted February 23, 2015 Share Posted February 23, 2015 Tee hee. How ironic is that?!?!? Link to comment Share on other sites More sharing options...
DietCoke Posted February 23, 2015 Author Share Posted February 23, 2015 Thanks for the replies, folks. I had looked at the Unselected and cleared it out, but found that it wasn't applying. After review I'm sure I did this to myself... I made a copy of the entire Ambient Occusion directory and was editing and using that one instead. For some reason it didn't seem to update consistently, so I'm assuming there's some sort of path in there possibly hardcoded? Not sure and haven't had time to investigate much yet, but after copying my changes from the copied directory back to the original it seems that the updates are now applying. Thanks again! Link to comment Share on other sites More sharing options...
hansolo77 Posted February 23, 2015 Share Posted February 23, 2015 Sounds like you figure it out then? Link to comment Share on other sites More sharing options...
Draco1962 Posted February 24, 2015 Share Posted February 24, 2015 Thanks for the replies, folks. I had looked at the Unselected and cleared it out, but found that it wasn't applying. After review I'm sure I did this to myself... I made a copy of the entire Ambient Occusion directory and was editing and using that one instead. For some reason it didn't seem to update consistently, so I'm assuming there's some sort of path in there possibly hardcoded? Not sure and haven't had time to investigate much yet, but after copying my changes from the copied directory back to the original it seems that the updates are now applying. Thanks again!It is possible that it had not been updated in the theme. When you open a theme in Theme Editor, it will load the available selector bars. If you copied the transparent one that I provided and overwrote the one that was originally part of the theme, you would then edit the existing theme to update what is within the Media folder. Link to comment Share on other sites More sharing options...
DietCoke Posted February 26, 2015 Author Share Posted February 26, 2015 Well, I'm not sure where I'm at at this point I was able to remove the underline, so that is fixed! I've got a new one though, so I'd say mark this one as resolved... I'll pose the new question in a new topic. Thank you! Link to comment Share on other sites More sharing options...
