New to the gamex community and have a little issue. When messing around with some themes, the "change view" for one view with all games are listed horizontally don´t display so I cannot (easily) change back to another.
Is there a shortcut for "change view"???
Hi bluetrain and Welcome to the GameEx Forums!
The "Change View dilemma" is not uncommon among new users of GameEx, but once you figure out the basics of how to do it from within the interface you'll be whizzing through various views in no time.
If you are in a "horizontal" view type, the change view icon can typically be reached if you navigate almost fully to the right in the topmost navigation menu. If you're in a "icon based" view the the Change View icon looks like a computer monitor displaying stars. If you're in a "text based" view it will simply say <Change View>. You may need to change views a few times before finally getting back to your favorite.
Good luck with this, and feel free to report back if you run into problems or if the above description is unclear.
  • 8 months later...
I know this was posted last year but I just want to say THANK YOU!!! I was stuck on horizontal view and was going insane trying to figure out how to revert back to the text/list view!
Given your success with nP's recommendation I think its safe to say this is resolved.
Thanks for reporting that it worked for you.
