GeorgeT Posted December 22, 2014 Share Posted December 22, 2014 Hello friendsRecently my SlikStik control panel trackball has decide it would only go up/down, not left/right. Has anyone had this issue? Any ideas on how to fix it?Thanks for your time & help Quote Link to comment Share on other sites More sharing options...
Adultery Posted December 22, 2014 Share Posted December 22, 2014 If you mean that is happening in GameEx turn off can friendly controls.Otherwise you may just need to take out the trackball and clean it out on the inside. Quote Link to comment Share on other sites More sharing options...
tthurman Posted December 22, 2014 Share Posted December 22, 2014 (edited) Hey George, I moved this over to the Social Club, as it will probably gain more traction than in the GameEx projects area.Mechnically, it's just a big mouse ball it would seem, and most likely it's a Happ.Probably needs a good cleaning and or some lubrication.I found this thread, you may want to give it a quick read.Then again, it could be this ! Edited December 22, 2014 by tthurman Quote Link to comment Share on other sites More sharing options...
tthurman Posted December 22, 2014 Share Posted December 22, 2014 Ninja'd Quote Link to comment Share on other sites More sharing options...
GeorgeT Posted December 24, 2014 Author Share Posted December 24, 2014 I did a little research (haven't taken the contoller apart yet) and it looks like one of the circuit boards might be bad.it works the same either within or outside of GameEx, the trackball for sure doesn't work horizontal (the mouse works just fine so it probably aint a setting that's messed up) Quote Link to comment Share on other sites More sharing options...
