DazzleHP Posted September 15, 2014 Share Posted September 15, 2014 I'm at my wits end!I spent nearly allday yesterday trying to figure this one out, but no matter what i try, or what method i use i get the exact same error! And it relates to the driver model1.c. As you guys probably know i'm not a codie and so i have no idea what the error means other than it relates to that file.After hours of searching (no exagerating), the only info i found was this, but as you can see, the person who reported the problem is trying to build in linux.The linked error (is the same as mine):src/mame/video/model1.c: In function 'void draw_quads(model1_state*, bitmap_rgb32&, const rectangle&)':src/mame/video/model1.c:307:17: error: array subscript is above array bounds [-Werror=array-bounds] while(p[ps2+1].y == cury) ^src/mame/video/model1.c:319:17: error: array subscript is below array bounds [-Werror=array-bounds] while(p[ps1-1].y == cury) ^src/mame/video/model1.c:319:17: error: array subscript is below array bounds [-Werror=array-bounds]src/mame/video/model1.c:329:17: error: array subscript is above array bounds [-Werror=array-bounds] while(p[ps2+1].y == cury) ^src/mame/video/model1.c:329:17: error: array subscript is above array bounds [-Werror=array-bounds]Compiling src/mame/video/segag80v.c...src/mame/video/model1.c:305:17: error: array subscript is below array bounds [-Werror=array-bounds] while(p[ps1-1].y == cury)I've downloaded mame-source and mingw multiple timesI start with fresh extraction of mame source every timeThe first few times i tried with my usual alterations to the sourceThen multiple times with zero alterations or diff's addedI tried Headkaze's compiler too, and although it ploughs through the error, it ultimately still fails a few moments later everytime.Has the compile process changed? Or is there a real bug in the source? I tried to compile over 10 times (i can be determined when i want to be ) but i surrender. Please someone tell me they know what's going on here. Pleeeeeeeeeeeeeeeease EDIT - OK i just tried 32bit version to make sure it wasn't a 64 thing, and sure enough same error. I took a screenie this time though:SOLUTION:Do not use the "new" tools promoted on the official page - they cause errors. Instead use an earlier version - this version is proven to work:http://mamedev.org/downloader.php?file=tools/mingw-mame-20121207.exeYou should point your grattitude to tthurman, otherwise known as Todd for finding this solution! It's all him! Thanks again man - you preserved my sanity Link to comment Share on other sites More sharing options...
tthurman Posted September 15, 2014 Share Posted September 15, 2014 Vanilla MAME?I'm compiling right now, via Headkaze's compiler, and so far so good!You are downloading the 0.154s and not the binaries, right? It doesn't differentiate between 32 and 64 bit, so I'm confused by that comment. 1 Link to comment Share on other sites More sharing options...
DazzleHP Posted September 15, 2014 Author Share Posted September 15, 2014 Vanilla MAME?Absolutely You are downloading the 0.154s and not the binaries, right? It doesn't differentiate between 32 and 64 bit, so I'm confused by that comment.Ofcourse it wouldn't even start if i tried to compile with a binary. It depends which env you choose - either 32bit or 64bit. I've been compiling my own since .143. I tried both the .zip and the windows only self extractor but both return the same error. Usually i can spot my own mistake if i make one, but after 10+ tries either there is a bug somewhere, or i'm losing the plot. I'm betting on the latter if i'm honest And yes, mine compiles for about 15 mins before it gets to that error.EDIT - also, as mentioned, Headkazes Compiler (which i don't normally use) ignores the error, but fails anyway a few mins after. Well for me it did Link to comment Share on other sites More sharing options...
tthurman Posted September 15, 2014 Share Posted September 15, 2014 (edited) hmmm, well that is odd. I just finished at 20:40, no errors.<edit>oh yeah, I recall that now from compiling the way detailed on Mr. Do's, doh Edited September 15, 2014 by tthurman 1 Link to comment Share on other sites More sharing options...
DazzleHP Posted September 15, 2014 Author Share Posted September 15, 2014 Ok, so the question is, why is it not working for me?! I tried with MAME Compiler twice (after the 10+ times manually) and it still failed. Remember this ain't my first rodeo. This is driving me nuts! Link to comment Share on other sites More sharing options...
tthurman Posted September 15, 2014 Share Posted September 15, 2014 UAC?Right click and run as administrator during extraction, could be a blocking what it sees as potential threats. Link to comment Share on other sites More sharing options...
DazzleHP Posted September 15, 2014 Author Share Posted September 15, 2014 It's turned off. Hang on - maybe that's why?! Is yours on or off? Link to comment Share on other sites More sharing options...
tthurman Posted September 15, 2014 Share Posted September 15, 2014 I just got in the habit of right clicking.I worked through this same issue with GeorgeT a while back, and that's what it was. It takes me a while to recall things more so than I'd like to admit 1 Link to comment Share on other sites More sharing options...
DazzleHP Posted September 15, 2014 Author Share Posted September 15, 2014 So you think turning UAC back on and then explicitly running as admin? That's what i get for running XP way past it's time PS: i'm compiling atm, minus an option i didn't think to try as it's always worked in the past... Link to comment Share on other sites More sharing options...
tthurman Posted September 15, 2014 Share Posted September 15, 2014 UAC in XP ? UAC was introduced in Vista. 1 Link to comment Share on other sites More sharing options...
hansolo77 Posted September 15, 2014 Share Posted September 15, 2014 I compiled recently just fine. You only have 1 version of the mame source in your folder right? Also, the only diff you need (unless you're building the UI) is the highscore one, there are no u patches yet. And make sure your checkboxes in the extra options are all setup correctly.One thing I noticed, and I hope HK will update the compiler for. There needs to be a way to have you choose an OUTPUT folder, so you don't include the src folder when you're done compiling. It's like 200+ megs of unnecessary fluff. Also, the compiling options only include Win32 OS, yet we're compiling a Win64 build. Might have something to do with your problem.One last thing. Did you try restarting the compile after it craps out, without erasing everything and starting over? The first time I built, it gave me an error, but I just started it up again and it continued on. Link to comment Share on other sites More sharing options...
DazzleHP Posted September 15, 2014 Author Share Posted September 15, 2014 UAC in XP ? UAC was introduced in Vista.I meant, i used XP for way too long before i upgrade to W7, so all this UAC stuff is new to me - which is why i turned it off I compiled recently just fine. You only have 1 version of the mame source in your folder right? Also, the only diff you need (unless you're building the UI) is the highscore one, there are no u patches yet. And make sure your checkboxes in the extra options are all setup correctly.Yes, yes, of course built my own since .143... by the way i don't use the compiler - i only used it twice yesterday to make sure i wasn't being an idiot Link to comment Share on other sites More sharing options...
tthurman Posted September 15, 2014 Share Posted September 15, 2014 I meant, i used XP for way too long before i upgrade to W7, so all this UAC stuff is new to me - which is why i turned it off Okay, yeah you threw me on that one.Did it compile this time less that option? 1 Link to comment Share on other sites More sharing options...
DazzleHP Posted September 15, 2014 Author Share Posted September 15, 2014 So to clarify:I use this mame source:http://mamedev.org/downloader.php?file=releases/mame0154s.zipI also tried the self extractor after many attempts with the source:http://mamedev.org/downloader.php?file=releases/mame0154s.exeI use the mingw env from official site:http://www.mamedev.org/downloader.php?file=tools/mingw-mame-w64-20140905.exeAfter each fail i delete the mame source, it is gone, the whole directory. Then i extract it again so it is fresh. Same error and i've tried everything. Apart from Todd's UAC thing. I always "Run as Admin" anyway as it stops the annoying popups, but now i'm gonna turn it back on and try again coz you just never know.@Todd - no it didn't work, same error @Han - why would i apply a diff that didn't exist? Link to comment Share on other sites More sharing options...
tthurman Posted September 15, 2014 Share Posted September 15, 2014 Okay, so I'm all setup to re-compile using the newer minigw you linked, and at about seven minutes in, guess what?Here is the minigw Headkaze has linked:http://mamedev.org/downloader.php?file=tools/mingw-mame-20121207.exeThis is what I complied with at first, and without issue. 2 Link to comment Share on other sites More sharing options...
DazzleHP Posted September 15, 2014 Author Share Posted September 15, 2014 Okay, so I'm all setup to re-compile using the newer minigw you linked, and at about seven minutes in, guess what?Scrnsht.jpgHere is the minigw Headkaze has linked:http://mamedev.org/downloader.php?file=tools/mingw-mame-20121207.exeThis is what I complied with at first, and without issue.That's the exact same error! I think you're on to something there tthurman! I'll try your linked toolchain and see what happens Link to comment Share on other sites More sharing options...
DazzleHP Posted September 15, 2014 Author Share Posted September 15, 2014 YES!That was it! I just tried a "true" Vanilla build with your linked env and sure enough - no errors. I now have MAME64 .154 compiled! WOOP!Thanks a lot man, i really was about to lose my shxx over this LOL and it turned out to be so simple in the end thanks to you You're a legend man! I'll mark as resolved with explanation Right after i compile with d-input and hiscore patch brb!PS: now i'm going @ -j5 so shouldn't take nowhere near as long. Compared to your (assuming) i7 it will though hehehePPS: Yes i have an i3 with 2 cores, 4 threads slower than an i7 but very capable heheh 1 Link to comment Share on other sites More sharing options...
Adultery Posted September 15, 2014 Share Posted September 15, 2014 Is there perhaps a new version of MinGW that needs to be linked in? Or was the new one you used just because? Link to comment Share on other sites More sharing options...
DazzleHP Posted September 15, 2014 Author Share Posted September 15, 2014 Is there perhaps a new version of MinGW?Yep, and it seems it is bugged like hell! Todd sorted it though, it's all good in the end PS: hiscore.diff+d-input=success! Link to comment Share on other sites More sharing options...
tthurman Posted September 15, 2014 Share Posted September 15, 2014 PS: now i'm going @ -j5 so shouldn't take nowhere near as long. Compared to your (assuming) i7 it will though hehehePPS: Yes i have an i3 with 2 cores, 4 threads slower than an i7 but very capable hehehQ9550, but still holds it own! 1 Link to comment Share on other sites More sharing options...
Krakerman Posted September 15, 2014 Share Posted September 15, 2014 The problem I found was some games have issues with that build. For example Gauntlet Dark Legacy doesn't work. So I stuck with 0.153 for me until they fix that issue. Link to comment Share on other sites More sharing options...
