Anyone know where I could obtain some 'snap packs' (instead of downloading individually) for the following systems please;
Nintendo Gameboy (Not Advance)
Nintendo NES
Nintendo SNES
Sinclair Spectrum
And possibly;
Amstrad CPC
Apple 2
BBC Micro
Dragon 32
Nintendo Gamecube
Magnavox Odyssey 2
Sega Saturn
Virtual Boy
Bandai Wonderswan
I am not asking for roms, just the SNAPS :)
2nd that
I just subscribed to Emu yesterday, and a combination of GameEx and EmuMovies made for a painless installation, as everything that was needed was automatically downloaded.
Highly recommended!
ok I have taken a look and it appears $30 or $60 per year which isn't bad to download all I need. Is it easy to use/setup within GameEx?
Do you notice the quality difference between 480p and 240p considering the menu is taking up most of the screen display (and its a small square showing the vidoe snap within gameex).
Also do you need much room on the PC tfor these movies?
Thanks,
Neil
I picked the lifetime sub for $60, but I believe either gets you the 480p snaps.
I was only looking for MAME snaps, so I can't speak for the rest, but have no reason to suspect it works different.
In the configuration options you point to your snaps folder, enter username and pass, exit config, and open GameEX.
It downloads snaps that are available according to what games you have. In my case it was about 9 GB for a full set (w/o chds)
About as painless as it can get IMO.
I would just like to add that if you can, get the 480p vids! I know the default themes use quite a small snap/vid area but they are not indicative of the many user created themes available. Many of them use a much larger area and you'll notice the difference between a 480p vs 240p a mile away on an 1080p screen.
Of course if you are only intending to use an arcade VGA monitor or similar low res method then the 240p option may be better suited as you'll save quite a lot space.
Don't forget too, that if you want you can create your own theme and have the media window as big as you like ;)
ok thanks, will probably join up later. just out of interest can you specify to only grab snaps/vids for certain emulators or all within GameEx?
Yes, you can :) Take a look yourself! Go to Windows menu, All programs, GameEx, Download Artwork and Videos. As stated by tthurman it'll only download media for the roms you have, and the systems you specify ;)
thanks but im a little confusing when trying to purchase - its $30 for annual and $60 for lifetime but then it asks to add 480p videos for another $60? So total will be $90/$120 and not 30 or 60? Is that correct?
ignore my last comment, realised it was for the DVD's - joined up and will start it off tomorrow :)
Thanks for all your comments.
Emumovies - great!!! It doesn't find all my snaps and videos but hey its got most of them :) Thanks.
One last thing though, how do I get GameEx to show the Video Previews - I have stored them in the folders and pointed each emulator video folder to the location(s) but it still only shows the snap images?
If you're 100% sure of the paths you likely need to install some codecs. Most of us here use (the recommended) Sharks Codecs, as they work flawlessly and always get vids working properly in GameEx. At least i've yet to see anyone report otherwise and i've been here 3 years ;)
The standard edition will be fine for most people, but by all means install the advanced pack if you are so inclined. Be sure to read the instructions carefully if you're using a 64bit OS and want the 64bit version as usually you need to install the 32bit version first regardless.
thanks, all works well although the sound sometimes go a bit funny went going through the video snaps and some games that only have image snaps. I have turned the video snap sound off for now which is a shame.
Thanks for your help all - I will list all my emulators on the forums soon so I can then help others if required.
Neil
